I've been having these issues either since the start of the ownership almost 2 years ago or this year. It's getting worse so I'd like to get advice on possible solutions:
- The song USB drive played in the last driving session does not get played at new session. In fact, none of the USB songs show up. I have to touch "USB" then choose album/folder then songs again. This really drives me insane and made the song playing almost not usable - also unsafe as I always had to re-set the songs. I noticed that if I park the car only for an hour or two, frequently the song stays in car memory and plays automatically when I tried to drive again. It seems that the car goes into deeper sleep to save battery after longer time, and it wipes out the song memory. I have two USB drives. One for dashcam, another for mp3 songs. I tried to have only the mp3 drive, same issue. This happened occasionally in the first couple months of ownership, then more often or less often based on software updates. But since the recent updates a few months ago, it happens almost every time (unless I drive again within 1-2 hours).
- Dashcam USB drive only gets used a few GBs. I tried USB3.0 with 32GB size or USB2.0 with 16GB size, the drive doesn't get used in full at all. Sometimes it just switches to on-board storage for driving clips, making the USB useless and impossible to save long trip videos. This is much worse than any dashcam I've had, which seamlessly recorded videos and looped perfectly fine (some had occasional hiccups but not like my teslacam). I made sure I followed formatting instructions too, and it's not like it always uses 4GB and stops. Fairly strange and frustrating.
- Another thing worries me is this year, when I first started max AC, a very pungent bad smell came out. I thought it was just some staleness and indeed it went away after some driving, but not completely. Every time I parked the car for a day or two, then drived, it'd have such smell. I had to open window to let it out. It happens for heat too, and happens whether using indoor air circulation or air from outside. Is this air filter problem? The issue happened when I only got the car for 1.5 years. I might give it a try anyhow - would the Model 3 filters on Amazon work?
- In recent months, my Model 3 began to ask for the black key card often. Used to be I can always use phone. I didn't even bring the key card usually. But now I could be stranded if I didn't bring the key card with me, as it often asks for it. It even happened a few days ago when I was in the car waiting for 40 minutes and air & music were on! Why would Tesla needs validation again when I never exited the vehicle and it detected that (since it kept air/music on)? Is this an update of the Tesla software? Didn't seem to be issue with deep sleep of my Tesla app on phone because even if I make sure the app is active and then enter the car, it asks me the key card scanned!
UPDATE on #4: I just realized it might be that recently I've disconnected bluetooth more often than before due to some issues with bluetooth devices. I need to double check if issue #4 only happened when I disabled bluetooth (which I believe is the proper behavior). I'll delete this point if this checks out, which means #4 is false alarm.
