AC energy consumption higher than heat pump?
gottagofast
2022 Model 3 Performance
Jan 28, 2024
548
236
Weather is starting to warm up some, 80 degrees today, so I used my AC for a decent amount of time for the first time today
I had the AC set to 70 degrees, just going by this 1 time trip the energy consumption seemed a good bit higher than my heat pump when it was 35+ degrees outside
Is this correct? Any research showing the AC uses more energy
Perhaps. The Tesla heat pump draws heat from many sources, such as the electric motors, so in a sense it is collecting a portion of the heat for “free” and then dumping it into the cabin. When the car cools there is no free “cold” air thus the heat pump must “create” it.
Oh I didn’t realize the heat pump was used for cooling too
Reactions: Lance From Jax
The preconditioning system is capable of pulling a significant amount of power in the right conditions.
This shows a 2022 Model 3 Performance pulling 12 KW while preconditioning in Park.
Everyone always acted like the AC energy usage was so low that it wasn’t even noticeable, when I read about these cars before I bought one
With the heat pump it is low. It all just depends on what it is doing. 12 KW is max that you will see. Typically it is negligible if you are just running the A/C.
Remember preconditioning for supercharging is trying to get that battery pack above 132 degrees F. That is an incredible amount of power if you are doing it quickly.
Reactions: rpiotro
