I continue to want to add some EV charging circuits to my garage, BUT, trying to find out if what I want to do can even be coded. If not, need to change direction.
I have a 400 amp feed, 200amp per subpanel setups.
One 200amp feed goes into my garage subpanel. It has my 4 heat pump compressors on a 100amp breaker. Has 15Kw of solar in a generation panel with 3 powerwalls. It also has like 5 20 general purpose circuits for the garage. One 240 for my air compressor.
What I wanted to do is tap off this feed with another 200 amp subpanel into my garage. There ideally I would love to have up to 5 with 60 amp breakers to feed tesla chargers.
BUT, as I think about this, what is code for what they will allow? Meaning, I am dumb enough assuming that if anything were to pull more than a total of 200 amps, the breaker would blow. Meaning, all the wiring subpanels, etc could never exceed their specs. But, I could make the breaker blow, technically, if I wanted to turn everything on.
Now, if the above is not able to be coded, meaning I could add no extra circuits to this feed, then I am thinking what are my other choices?
Currently I have 2 SE 11.4K inverters in the garage on 60 amp circuits? SE does have this kit, which I assume allows one to add, and I assume can charge even with the inverter off at night? But could one also just tap these lines with a 14-50 connection so I could use telsa chargers?
Or what other ideas do folks have that I can get a permit for.
So far I have not found a person who really knows this stuff to give me the best direction to go.
But this group, with all the experts, I hope can lead me the right way.
