Thank you for your inquiry. If you are thinking in the future about lowering your vehicle our 19" wheel will not rub. As for the brake caliper covers the will most likely fit but we have no experience with caliper covers.
Best,
T Sportline
Lydia Sanchez | Customer Service Specialist
Direct: 310-880-3256 | Toll Free 866-991-4776
I'm confused i just received this email....lol
For folks that have replaced their wheels, how did you get your TPMS to work? I got a set from eBay which is supposed to be pre-programmed for the 3, i got my wheels mounted this morning and after driving for about 30 miles, car is throwing error message "Tire pressure system needs service, contact Tesla service". I thought it was be plug and play.
For tpms, it didn’t take me 30 miles, maybe 10 at most, but during that, I went past 50 mph on freeway, and that screen popped up to select wheel size as a new tpms was recognized.
You can try to press both scroll wheels down for a soft reset, screen will be dark for a minute and may prompt that screen?
View attachment 345891 View attachment 345892 View attachment 345893 View attachment 345894 View attachment 345895 View attachment 345896 Finally got around to taking some pics. I’m lowered on Tsportline springs (about 0.75” drop for me) with duplicolor blue calipers. Thanks to Josh from getyourwheels. Enjoy!
20” Forgestar F14 in Kingsport Gray
Rear: 20 x 10.5 +43 (deep concave)
Front: 20 x 9.0 +32 (semi concave)
Michelin Pilot Sport 4S 285/30; 245/30
View attachment 345895 View attachment 345892 View attachment 345896 View attachment 345893 View attachment 345891
Hi
Really like your wheels. Where did you get them and do you know the weight. Thanks!
I got these on eBay and they work fine. They were detected in about 5 miles.
4x ITM TPMS Uni-Sensors Metal Clamp-On 433MHz for Tesla Model 3 2017-2018 667952810783 | eBay
I assume they can be programmed without removing them from the wheels. You’d just have to find a tire shop with the right programmer. Definitely complain to the seller though!
Reactions: juanmedina
If they truly are preprogrammed correctly, then the next step is to make sure your tires are inflated to the proper PSI. I was also having the same issue as you, but the tires were running around 38 PSI.
Inflated them to 42-43 PSI, and the next highway drive, the selection screen came up and I was able to choose 19".
