I love my aftermarket wheels. Fast FC04. Make sure you go to an installer that knows Tesla well so that they can choose a wheel that is appropriate from a weight/balance perspective.
Had these on my previous car, a mustang, and fits perfectly on the model 3. Wheels are TSW Bathurst. I’m thinking of powder coating them a satin black but I’m liking the silver and white combo too.
Reactions: pkalhan and Hayden
SD, those look amazing!. Love the knurling and cutouts on the spokes!.
How long was the wait after you ordered?. For those of us without the mpp rotors, do they offer a hub ring that will work?
Thanks! No wait because they had them in stock.
The wheels have a 72.6 bore, so they'll fit over the lip. Because I have the MPP rotors, I'm able to use a set of 72.6-64.1 hub rings from Evasive. You may be able to buy the same ones and have a machine shop mill them open to fit over the lip.
Well, the actual hub bore is 64.1mm, but the protruding lip requires that you size the wheels to fit a 70.1mm hub.
You might be able to see the larger lip in the picture:
Makes much more sense! Thank you!
The center bore of the performance is 64.1mm. You have to either get a 64.1mm wheel that’s bored/chamfered out to accommodate the 3mm lip. Or you get a 70.2 mm or larger wheel with a custom centering ring that also accommodates the 3mm lip.
Here a good vid explaining it.
Great vid! Thanks a lot!
Gotcha. Do you know if the MPP rotors are heavier or weigh about the same the stock p3d rotors?. Thanks
