OK cool... it's been a bit since I've bothered looking and thought I had read the display had had info removed. Perhaps it was voltage and current info.In my S, it shows both now -- instantaneous kW and longer duration mph.
Remember that rated range in a Model S is based on about 320Wh/mi, and Model 3 is about 260Wh/mi. So 480mi/hr in a Model 3 is 125kW, which would show up as 390mi/hr in a Model S, only a little faster than the typical starting rate at low charge.Anyone else getting a whopping 480+ miles an hour charge? What’s more impressive is that the charge rate doesn’t seem to taper until very late, after 90%. I charged from 12 rated miles until 295 in just 45 minutes!
Just simply that it’s lighter, with only ~2/3 the cell count, but takes up the same volume.I've seen this battery density comment repeated before. What do you base it on?
If the answer is pack weight as compared to a S pack, are you accounting for all the other stuff in the mezzanine portion of the 3 pack that's not in an S pack?
Unless Tesla changed the charging profile, the Model 3 LR starts to taper just under 50% on Gen2 Superchargers.Of course, the Model S starts to taper a LOT sooner than 90%, so a big win there. Also, with 310 miles range you might not need to charge more than 80% on road trips you you'd always be in the "sweet spot".
OK, where did that graph come from?Unless Tesla changed the charging profile, the Model 3 LR starts to taper just under 50% on Gen2 Superchargers.
Did you see the second part of my post?:Just simply that it’s lighter, with only ~2/3 the cell count, but takes up the same volume.
It was based on a handful of posted charging sessions but it mimics this data on the BT37. Tesla Battery Charging Data from 801 Cars – About A Better RouteplannerOK, where did that graph come from?
Sure did. I'm comparing 3LR to 3SR. I'd certainly expect the LR and SR packs to have the same stuff in the penthouse. So again, fewer cells in SR so less weight in the same volume = lower density than LR.Did you see the second part of my post?:
"If the answer is pack weight as compared to a S pack, are you accounting for all the other stuff in the mezzanine portion of the 3 pack that's not in an S pack? "
And I don't think we have seen yet the full capabilities of Model 3 charging with the next Supercharger version about to come online.
I bet the next Supercharger version will also come online with self plugging so you don;t even need to get out of the car.
Ah, I misunderstood the comparison... I thought it was being compared to the S pack.Sure did. I'm comparing 3LR to 3SR. I'd certainly expect the LR and SR packs to have the same stuff in the penthouse. So again, fewer cells in SR so less weight in the same volume = lower density than LR.
Do you happen to remember how long it took to charge from 121 to 248 Miles? Based on your reported mph I would suspect 15-20 minutes, does that seem close to accurate?
This curve seems pretty accurate from what I’ve seen. Although I’ve gotten a full 120 kW below 50%.Unless Tesla changed the charging profile, the Model 3 LR starts to taper just under 50% on Gen2 Superchargers.
My guess is that he does not realize that the miles/hour is averaged over the sessionNot quite sure what the OP is talking about claiming no taper until 90%.
No I did notMy guess is that he does not realize that the miles/hour is averaged over the session
Yup, charge rate (in kW) is pretty much the same for the 3 as S/X.
But the speed at which the Model 3 adds range (in MPH) is dependent on how efficient it is at taking those electrons and moving the car down the road. It is a more efficient car, so it adds charge faster when you look at the charge data in MPH.
The S is more efficient than the X, and will see higher charge speeds (in MPH). But the 3 crushes both of them.
Very nice. So the Model 3 doesn't charge all the way to 90% at full rate, but OTOH it seems to do so up to 50% charge, whereas the S85 only gets to 20% at full rate (which matches my experience). The Model 3 will be a great road-trip car.It was based on a handful of posted charging sessions but it mimics this data on the BT37. Tesla Battery Charging Data from 801 Cars – About A Better Routeplanner
I need to update it to include a ramp from zero, but don't expect it to be nearly as limiting as ABRP predicts. Either way, they've seen nothing near max charging power at 90%.
