Android Mobile App Using Baidu百度 Maps
Discussion in 'Model S: User Interface' started by mmh, Feb 16, 2015.
  1. mmh
    mmh Member
    SLC
    I'm hoping someone here has run into this problem and knows a fix. I've tried contacting Tesla 3 times now and no response.
    Previously the location feature on the phone app worked fine, then one day a few months ago, it decided I was in China. Now, I can't get it to go back to using Google Maps. I've tried uninstalling/reinstalling the app with no success.
  2. WanderinWhitlows
    Scott AFB, Illinois, United States
    Is it possible that your mobile device itself has something elsewhere that has it's location set to China and the app is picking up on that? I suggest this as I had a mobile phone that informed me that I was 7,278 miles from my destination across town before I realized that it had my "current location" locked to Gardez, Afghanistan.
  3. dasRad
    dasRad Member
    Kelowna, BC, Canada
    Have you turned off Google Play Services for the app or for the phone in general? I ask as the android app will run fine on a Blackberry z10, except for the Location pane which shows pretty much exactly what you are seeing. (No Google Play Services on Blackberry which causes similar problems with all apps requiring Google Play Services).
  4. mmh
    mmh Member
    SLC
    Good thought dasRad, that was a real possibility so I went through and verified. Both Google Play Services and Google Services Framework are enabled and functioning properly. I suspect it may be a setting on Tesla's end as to which mapping provider is used. I've dug through all the conf files for the tesla app and don't see anything that seems to control which map provider will be used.
  5. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    On a related note, I tried to install the DJI "drone" app on my Android and it would not install due to a permissions conflict with the Tesla app. The conflict is with the permission: android.permission.BAIDU.LOCATION_SERVICE
    Due to this, it is impossible to have the Tesla app and the drone app installed on an Android device at the same time (in Android 5.x)
  6. Eumox
    Eumox Member
    Austria
    I have the exact same problem as in post #1 with my new LG phone. This seems to be the only google result mentioning it. Has anybody found a solution to this?
  7. mmh
    mmh Member
    SLC
    Nope, I've basically given up with it. From my experience Tesla Support is a joke both in terms of app and car support. Luckily though, VisableTesla will still work from a computer to locate the car... Not much help if you forgot where you parked though =p.
  8. Eumox
    Eumox Member
    Austria
    I am not sure that it is Tesla's fault. I just updated everything google* (play*) on my new phone now. Now the Tesla app tries to show the google map in the location tab. Unfortunatly it crashes after a second. It seems to be an android issue. They can't support android problems. We just have ****** phones :)
  9. lagann
    lagann Member
    Boston, MA
    That's Chinese developers for you. Baidu gave the instructions to those apps to add that permission, then you end up with the problem you just stated. Which drone app are you referring to? I'm an Android developer, so I can look to see if I can find a workaround for you.
