The exact same thing happened to me on 7/18/19 in my 2017 Model S 90D (16,500 miles) while backing out of the driveway wheels turned left. Tesla replaced the broken fore link on the left control arm and also replaced the intact fore link on the right under warranty. I have reported the control arm failure to NHTSA.Reversing out of a parking space we heard a very loud sound followed by a grinding/scraping noise from the front right. At first we thought we'd run over something, but there was nothing under or anywhere near the car. Moving the car forwards, the car felt like it first jacked up a bit on the front right, then moved smoothly, but still with the scraping noise. Since we were very close to home we drove home at very low speed with varying degrees of scraping and other noises whenever we went over bumps.
Tesla towed the car to Watertown and are replacing a control arm as I write this the next day.
There have been several reports of this kind of failure happening, so I wonder if they've got a systematic problem.
Why are they sending you to a body shop for this? This is a mechanical problem that should only be repaired at a Tesla Service Center. If this did result in body damage, it would make more sense to fix the mechanical problem first, then send the car off for body repair.authorized Tesla body shop
Money. It's always about that.Tesla knows full well this is a common problem. Wonder why they are pretending that it isn't?
Good question. Not that this is what happened...… but, there are a few situations where Tesla will point you to an independent approved repair shop. One example is if another car hits a front wheel and causes the damage to the wheel and isn't the result of a failure.Why are they sending you to a body shop for this? This is a mechanical problem that should only be repaired at a Tesla Service Center. If this did result in body damage, it would make more sense to fix the mechanical problem first, then send the car off for body repair.
Original control arms still doing well after 204k miles on my P90D.
I also did not have this problem on my P85+ after 80k miles
I've seen the history of my current car, but not the previous S.How do you know they're original. Tesla didn't tell me that they'd replaced mine with the updated part until I asked them about it.
I'm the original owner of my car and have the full service history. They did NOT document externally that they had replaced my fore links.
Did you verify yourself that the part number was the updated one? Them performing undocumented work on your car seems super shady.
It's not like service techs haven't been wrong before.
the whole front left tire locked up
The tire ended up pushing against the rear of the wheel well and rubbed right through to the battery and my coolant all leaked out in addition. The tire has a gouge around the whole thing where it rubbed.
Isn't this:
sort of incompatible with this:
It sounds like the wheel was still turning, just rubbing hard against the body.
