Sprayed it again the day of my last post smell immediately disappeared and has not returned yet.
I suggest instead of Kool-it using Klima (I use 2 cans) during the filter change. I follow the full procedure twice. If any left in the can I wait until the foam is down and empty it. Seems to work better than Kool-it. Also check the intake. Leaves can be on the intake screen (accessed form the frunk after removing the top cover). I made an intake screen from gutter wire (from home depot) to catch twigs and leaves. Doesn't restrict flow but stops the big items.Okay that lasted about a week. Just did it again... But it works each time so far.
What did you used around the edges of the screen?I made an intake screen from gutter wire (from home depot) to catch twigs and leaves.
Did you take the filters out before spraying the anti fungal? If not, wouldn't all that spray just end up on the surface of the filters?Good information fellas! Just sprayed it again with antifungal. Will post each time I do it so you can see the frequency that's working.
A couple of things, the Model 3 and Y systems are virtually identical. Your point about leaving it on Auto mode is probably the KEY. I've never had any bad smells until I started using recirculation mode occasionally due to external air pollution.I'm convinced that this is the key, to keep the air on AUTO and to let the car/algorithm or whatever you want to call it do its thing. By having it on AUTO it dries out the coils and if you have your destination going on the Nav, you'll notice that it switches it to outside air before getting there.
Now let me ask, for those that prefer not to use the chemical sprays, what are your thoughts on spraying (spray bottle / mist) a mixed diluted solution of IPA >70% or Hydrogen Peroxide into the intake vent to help sanitize the funk? Since IPA evaporates quickly it should technically be okay?
You can use sprays, but like I said an an earlier post, the air flow path goes from intake > fan > filters > AC coils. So you need to take out the filters before you spray, or whatever you spray will just end up in the fan blades, then the filters. After numerous tests by myself and other forum members, it's very clear that the bad smells are NOT from the filters being fouled, and most probably originates in the coils.
From brief research, seems like H2O2 could discolor plastics or harden rubber, so I'm not sure if misting it into the intake and then having it spread all over the car in a fine mist would be the best idea. Also I'd assume to kill fungus properly you'd want the entire surface of whatever you're disinfecting to be covered in liquid form before drying.Do you think that misting IPA or H2O2 w/ the filters removed into the intake take would be harmless in terms of affecting any of the parts inside?
Never mind. I just found out that Tesla service had replaced them at 44K miles. So those only had 23K miles on them.Why aren't they dirtier?
Having the antifungal spray hitting the filter might not be effective if the smell is coming from the coils? But the smell could be from anywhere within the circuit, could be the drain just upstream of the filters, could be the fan blades themselves.I doubt the fan blades will prevent the spray from reaching the filter which is like a giant sponge. Also if the filter is wet, the antifungal spray will simply be present at a lower solution than if it hits a dry filter. Once the filter is dried out, the antifungal concentration goes back up.
Did u once again replaced the filter or just sprayed it? Mine didn't last but 9 days after filter change. I live in SC.Ok, it started to get stinky today, 3 weeks post new filter install and antifungal spray. Sprayed again today, will update when it gets stinky again.
I won’t use bleach because it can cause damage to your nose, throat and lung tissues. Use white vinegar instead, try different strengths eg 1:10 parts. Try getting high strength vinegars, those use for cleaning vs household cooking vinegar.I always knew the problem isn't with the filter. Today I confirmed it by taking out the filter and running without it. Sure enough it still stinks as always. This is AFTER I changed to a new filter, did the coil foam clean, & spray the coil/box with 1:10 bleach all done last week. Tesla has a design fault and likely killing my lungs with mold.
I believe I have done over 8 filter changes since buying the car in Aug 2020 with about 20K miles. The amount of filter I buy, Amazon must think I operate a fleet of Ys. Embarrassing.
After battling this nonsense for nearly 3 years I'm guess the problem is actually POST AC evaporator coil and heating condenser coil. With the amount of coil cleaner, bleach, and Lysol I sprayed into the system nothing is living where it can be accessed.Did you take the filters out before spraying the anti fungal? If not, wouldn't all that spray just end up on the surface of the filters?
The airflow of the AC system is like this: outside air intake -> fan -> filters -> AC Evap coil -> Heating condenser coil -> ducts. And if you put on recirculate, the outside air intake is blocked, and air is sucked in from inside the cabin directly next to the fan, which is just above the filters.
I'm assuming most of the sour smell is from some kind of accumulation in the AC coil, however, last time after I flooded the whole filter space with cleaning foam, I could still smell like 2% of that sour smell quite soon after, so it wouldn't surprise me if whatever's growing is also on the heating coils or the low spots in the ducting around those areas.
Weber Auto video about the whole heat pump system where you could see a detailed view of the components taken out of the car.
