I just finished replacing the cabin air filters on Nick (see sig). Here are some tips:
If you have a car with the screw at the top (2020 or earlier?) of the cabin air filter cover, this is indeed a tricky procedure. Watch YouTube videos on this before you start.
1. If you rarely use the AC, you may not need to replace the filters often. After 2.5 years and 67K miles, mine were not very dirty (old on the left, new on right).
2. Use a headlamp.
3. For the models with the screw at the top of the filter cover, I recommend that you buy something like this for removing the screw (note it's a Torx 20 screw head):
I improvised something when it turned out that my stubby screwdriver didn't work (see yellow thing in the filter photo above).
4. I recommend you buy this on eBay for replacing the screw for next time. It looks like it's too short to work, but it works fine:
3. Pay attention to the number and location of clips when removing the under-dash part. You need a lot of force to remove the speaker clip.
4. Cover these openings with something so nothing can fall in there:
5. You'll want to spray the coils with AC coil cleaner and then run the AC for 5-10 minutes to dry things out (before putting the filters back). When you do that, put the cover on or otherwise cover the opening or foam will spray out into the car.
Bottom line, it's doable but a bit annoying and tricky.
2. Use a headlamp.
