I'm always sceptical of solar-powered lights. In winter (when you need them the most). In the UK.
If your solar intensity is anything like my current one, I doubt 2 days will do the trick. My solar array hasn't even kicked in yet!You and me both. That’s why I reckon it’ll only last a year. Gonna try the “easter egg” ten press trick tonight whilst I’m waiting 2 days to charge the solar light. Of course this is only a solution if you have the Tesla “Wall Connector”.
the only place I need to open the charge port door in darkness is at home.
I was actually surprised to find that my solar security lights are still working fine and have been operating perfectly summer and winter for a few years now! I bought a pack of 4 even though I only use 2 because I expected them to die once the first winter kicked in … so I’ve still got the 2 spares in the cupboard unused! Believe it or not they’ve been in use since January 2021 (they already had enough charge to start them off so even worked despite starting off at the darkest time of the year… in southern Scotland. )If your solar intensity is anything like my current one, I doubt 2 days will do the trick. My solar array hasn't even kicked in yet!
yes.. useless in winterI'm always sceptical of solar-powered lights. In winter (when you need them the most). In the UK.
I can believe it, I know I have a Ring camera charged by a small panel and it never has any issue with even the depths of winter. It does help that it's on the South side of my house, I imagine the North side wouldn't work nearly as well (as it would be on the wall in shadow)I was actually surprised to find that my solar security lights are still working fine and have been operating perfectly summer and winter for a few years now! I bought a pack of 4 even though I only use 2 because I expected them to die once the first winter kicked in … so I’ve still got the 2 spares in the cupboard unused! Believe it or not they’ve been in use since January 2021 (they already had enough charge to start them off so even worked despite starting off at the darkest time of the year… in southern Scotland. )
Yes, mine are only set to come on for a short while when triggered. Mind you they do get triggered a few times through the evening due to some passing traffic. I would never expect solar lights to last long in continuous operation in the winter… but that’s not what I need anyway.Good to know. I think mine would be useless in the mode where the light stays on dim all night and bright with movement. But the mode where it only comes on for 30 seconds should be good all year round as well.
Switched mine on last night (impatient !)
Worked great (one day in ). Except obviously the setting 1) and setting 2) switch works in reverse
And ... ??I 3D printed a little white plastic bracket, lined the groove where the betalight sits with aluminium foil, as a reflector, and fitted the whole lot together:
Just need to wait until it's pitch dark and see if this gives enough light to be able to see where to stick the plug in.
You are replying to post that’s more than 4 years old …. and OP is no longer on this forum.And ... ??
And ... ??
