you can have a thermal store associated with that (that you may want anyhow) and pre-heat the incoming water through that before going to your hot tank
Just in case anyone else goes down that route, we did that and then did a bit of a volte-face.
We put in Accumulator for old part of house (house is big, so is Accumulator), heated from biomass batch boiler (light it, let it burn completely; you then have to have somewhere to store the heat). In summer the Solar Thermal heated it, and top half got to 60C, and we heated the DHW direct from that (i.e. a DHW coil in the Accumulator). Trouble was it was touch and go to get it to 60C (2,500L tank!).
So we redid it and added a tall-thin Solar DHW tank with Solar coil. Now the Solar Thermal heats that as a priority, and then dumps heat into Accumulator. Supply to DHW tank is pre-heated in Accumulator (so, in mid Summer, the top-up water into the DHW tank is 60C
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Works well (and we have the ability to dump any excess heat from Accumulator into Pool, in addition to Solar Thermal panels which are dedicated to the pool or light the biomass boiler to heat the pool (via Accumulator). The flexibility is a boon ... I could add an ASHP into the mix if I wanted to).
This isn't for the feint hearted, and your average Corgi Plumber won't be the least bit interested in helping out ...
I have a mega fireplace ... smallest stove you can buy gives out much more heat than the total requirement of the house!
We have a tiny-ish Wood Burning Stove which is Passive House certified. Basically it draws its combustion air from outside. By trick akin to optical illusion the "body" of the stove is big, but the combustion chamber inside is very small. I expect it might still be too many kW for you, but I'll send you the details in case.
We like our Stove. At the shoulder ends of the season we light that, instead of the Boiler, and the MVHR does a good job of distributing the heat. That said, the Biomass boiler gasifies the wood, and is incredibly efficient. The Stove is very good, but it does seem that we get through quite a bit of wood (the boiler's job is to do a lot more work, so my "comparative log measurement" is very subjective!!). But we also have some feel-good of seeing the flames in the stove, through the door to that room, every time we walk down the hall ...
You are presumably not talking about a brick house?
Yup. Needs an air tight membrane/layer as well. Turns out that Breeze blocks are ... just that. Amazes me.
Not sure I can easily describe this, but I'll try.
We were at the point of having an outside wall - brick outer, cavity (full of "fluff") and block inner. At right angles to that a block internal wall was being built, butting up to the inner-skin of the exterior wall. It had a "hole" knocked into it where a socket was going to go; probably 2~3M in (from the joint with the exterior wall). Passive House consultant rocked up for one of his regular visits. "
Was the [inner surface of] that external block wall parged before the inner block wall was built?" ... builder had no idea that was needed, so "
No".
Passive House guy say "
Air will go in to that power socket, along that 3M of wall, and out through the exterior block wall". He got some pretty surprised looks!
If you plaster the wall then that is air tight. But of course when a plasterer does that he doesn't bother with all the bits behind pipes that are going to be covered with a "vanity board" and so on. And that's where the problems start. We needed to have "plastered" (parged) the wall where the internal wall was going to meet it. normal block-laying just has some hit-and-miss mortar in the joints. Every house ever built has that problem, so in converting existing houses to "air tight" it is ... really really hard, as we discovered trying to do ours.
Passive House has to be built right. It can't be sorted out at Snagging, as UK builders tend to fix (as in "bodge") everything. They may need to learn some new stuff, but there is nothing onerous.
