I found them on ebay for $40. If anyone plans to install this here's a tip: install sound deadening material either on the trunk ceiling or on the inside of the mat. It's not going to reduce all noise but it will help a little bit.
If you have the see-through mesh opening in your rear deck (pre 2019 models) you will notice a bit of sound difference, I did. If you have the solid deck then probably won't notice much. If you do this mod mainly for the aesthetics and clean look, you will be happy with it.
I covered that hole on mine as an experiment last year and decided to leave it on. I cut a piece of packing foam (like you might find when you buy some electronics to protect them in the box) to just slightly bigger than the opening. I then wrapped it up in some black acoustically transparent material (used to cover speaker grilles). I just had these materials on hand and didn't need them, so it worked out.Nice. I may try the felt tape to cover the gaps as well since I haven’t fully attached it. I have been debating covering the metal with some noise reduction material before using the adhesive tape. I also have a 2018 with the mesh covered hole that is no longer there in new models and have been trying to figure out what to use to more thoroughly cover it. Let me know if anyone has suggestions.
That's exactly what I have. I have the hole in the middle. Now with the hole covered up....there is a tremendous difference.
Of course there are people in this forum who never had the hole commenting and disliking my comment not knowing there are 2 different Model 3's out there concerning this hole.
What's your recommended sound deadening material? This is what i've been wanting to do since just covering the mesh hole in the deck hasn't improved the sound much for me personally.I found them on ebay for $40. If anyone plans to install this here's a tip: install sound deadening material either on the trunk ceiling or on the inside of the mat. It's not going to reduce all noise but it will help a little bit.
If you have one of the earlier models with the hole in the trunk ceiling, the cover measurably reduces noise:
Trunk Top panel
Of course, YMMV on whether it's noticeable to you.
https://www.amazon.com/dp/B0751CBXB...olid=3IXIC9E1TAZHO&psc=1&ref_=lv_ov_lig_dp_itWhat's your recommended sound deadening material? This is what i've been wanting to do since just covering the mesh hole in the deck hasn't improved the sound much for me personally.
This is what I ended up using
