Argh. Fixaflat. Fills the interior of the tire with Gunk, and the gunk gets all over everything, including the TPMS sensor.I could not get rasp tool to penetrate. Maybe if I could have unmounted the tire but I'm not set up with proper tools to do that. Hopefully one day for next flat.
So, a trip to Walmart in my other vehicle and I decided to try Fixaflat. First time trying this stuff but after letting the can empty into the tire per instructions, airing up to 45lbs and driving a bit, it is still holding this morning. Now I am off to my local tiee shop to let them inspect and hopefull plug that nail hole proper.
Thanks for the great advice. It is perfect.
I plan to pack a can of Fixaflat and a 12v compressor next!
Further, for noise-quieting purposes, quite a few (but not all) tires for Teslas have sound-deadening material (foam) on the inside of the belly of the tire.
When a tire shop does a flat, they take the wheel off the car, dismount the tire, cut away the foam, put a patch on the inside of the tire (looks just like a bicycle inner tube patch), puts the foam back on top of the patch, puts the tire back on the wheel, inflates, and checks for leaks. Costs maybe $50, tops, and the $100 TPMS sensor is Just Fine.
The plug approach is not precisely official and carries risks that it might come loose, although plenty of people (including yours truly) have had success with the thing, which doesn't require actually taking the wheel off the car.
Your TPMS sensor is now Toast. Fixaflat is fine when you're out in Death Valley, no phone service, and the vultures are circling. Otherwise, you'd be better off calling for a flatbed truck to come get you and take you to a tire place.
My 3 month old rear tires are Continental Sport with no foam. $100 cheaper than what Tesla has sold me im the past and I notice no difference in sound.@Pstreicher1
BTW, Fix-a-Flat notes that its sealant shouldn't be used in quiet tires, as those have a layer of foam on the tread
Of course!You need to inform the tire shoppe that you used fix-a-flat. That is bad stuff for them to inhale.
