Autocross- SCCA EV-X Class vs. SS
Much slalom.
All,
My cheap-o Federal 595Rs-Pros in 275/35R19 only have maybe a couple more events.
Definitely stepping up to I expect some RE71RSs.
Question: Should I go down to 265/35R19 on my current 19x9.5s, OR stick with 275/35R19 and go to a 19x10.5 (Probably Konig Dekagrams)?
Would going to a 285 on a 19x11 be worth it?
All,
You planning on cutting your fenders or shaving your uprights? If not, 11s won't work.
You could go 275s on 19x10.5 easily enough.
  • Disagree
Reactions: superflyrolla
All,
When I look at TireRack's site, the RE71RS size availability does not show 265/35/R19; just 275/35R19 and 285/35/R19.
Reactions: Clover
@gearchruncher @MasterC17
I remember MasterC17 reporting his car drove better on the 275s once he went up to a 10.5 wheel, but I don’t recall if he actually got faster because of the change.
But, bottom line, if I am already having issues with tread temps, then it seems valuable to go wider (and not shorter, either). That said, understanding the performance gains by keeping the wheel around 10% wider than the tread width, I don’t have too many options above 275.
There's a noticeable increase in steering response and sidewall stiffness on 275's vs 305's on the same wheels, IMO.
That being said, I don't have direct laptime data. Tire Rack did, however, do a good test using the same basic concept, and more rim for the same tire is generally faster.
Reactions: Lindenwood
I've seen multiple 3s with 11s on stock body work now. The SSP car at spring nats was rumored to have 12s in the rear.
The rears are/were never the issue. It's always the fronts. Like I said, your either shaving the upright or cutting/pulling fenders. You can't fit a 18x 11" without it. Maybe possibly running 19x11 with a very short 25"ish tire. Maybe.
The only other potential alternative is using a MY front upright. I've heard 2nd hand there's more clearance going that route, but haven't seen it yet.
For the rears, I could see 12s with 335 fitting without much work.
This weekend I'll see if I can throw on a 18x11 with 315s up front.
Of note, I was talking about 19x11, not 18x11.
Reactions: The Other Dan
So, if you guys were splurging for a possible trip to the Nats, would you go for 295/30/18 Yoks with 98XL load rating, 25.1" diameter, 26lbs per tire, 11.2" tread width, or 295/35/18 Yoks with 103XL rating, 26.2" diameter, 27lbs per tire, 11" tread width?
