Axle seal leak
Decided to rotate the tires today and noticed that the rear axle seals are leaking! The car has just 15k miles and is 6 months old. How is it possible? Defective seals? Or maybe the differential is not balanced?
Mine looked similar. Tesla service claimed it was just road grime and cleaned it. Has this happened for anyone else? At least if my axles or drive unit fails, they will have the record of me bringing it in with the concern of leaks. Mine is on the front drive unit.
Yup looks like road grime. Define road grime: it is dust and road dirt adhering to liquid leaking from a seal. Jeeze! Did they notice the pattern of the road grime, only below the seal? Rediculous!
Reactions: zoppp and m73b54
Yeah that's what I was thinking and was adamant that it seems more serious than they are thinking. Well at least if it fails, they have me on the record showing the problem before the warranty period expires.
If the seal was leaking you would expect it to be slung upwards and sideways from the rotation of the shaft.
I would clean this area then recheck in a few thousand miles
Do we know if there is a service interval for the oil change or a level check at any point?
No seals in the car for any rotating shafts do not rotate with the shafts. Most oil leak occurs between the oil seal and the housing, not between the rotating shaft and oil seal.
So, most oil leak will drip down due to gravity and towards the back due to vehicle moving.
Yes, as long as it's not leaking there is no reason to check the oil level.
"Most oil leak occurs between the oil seal and the housing?" Are you kidding? 🤣
Reactions: Zedbox
According to tesla service, there should be 2.1-2.3l of oil (in the rear motor). But it looks like it's below the fill plug. So you can't just unscrew the plug to make sure that it's leaking out.
I have some good news! It turns out it is not an oil leak.
I visited Tesla today and with a technician, we looked at that area closer. Tesla uses original axle seals and they put some thick green grease inside these seals (the grease looks like grease for CV-joints). Excessive grease squeezes out and over time starts to degrade and its liquid component (like thin transparent oil) spreads down. Whether it is good or bad for the seal itself I don't know - time will tell, but it's not motor oil so there is no reason to panic.
