AlanSubie4Life
Efficiency Obsessed Member
Well, that actually says 332, rather than 333, which suggests you are slightly below the degradation threshold. Did you see it switch to 333rmi at some point after it charged for a while?Finally charged my car (2023 M3LR dual motor) to 100%. Still showing the same 77.8kWh and ~333mi rated range. Wonder if any other owner sees the same
It's quite possible that after a while it went to 333, I'm just asking for clarification. Basically there is a huge range of energies (above about 77.8kWh) which would display as 333 rated miles at 100% in the vehicle (these are energies that exceed the degradation threshold). But as soon as you see 332 rated miles and it won't budge up to 333, that means potentially that there has actually been capacity loss below the degradation threshold, and for example the degradation threshold might actually be closer to 78kWh (so 332/333*78kWh = 77.8kWh).
The constant still appears to be 234Wh/rmi (we have better accuracy on that now, 243Wh/mi*320mi/332rmi = 234.2Wh/rmi), and the rated miles for the vehicle at max was 333rmi (known from EPA sticker), so technically it is likely the degradation threshold is 234Wh/mi*333rmi = 77.9kWh.
So perhaps you are slightly below that now. If you showed 333rmi, and the energy screen showed more energy as well, concurrently (it should), then you aren't, though.
Of course, this is all just an estimate and as @AAKEE mentioned, this estimate can get adjusted up and down. And it may take some time. Long term, it will of course only go down.
