My almost 4 year old model 3 has battery degradation of 14.3% according to the Tessie app. in the little graph they show it shows me well below the fleet average. Is this somewhat normal for people or is my battery way worse than most?
What's your efficiency and charging habits? I see you're in Florida so it's not like you're driving in the freezing cold.So basically mine is really bad
Charge on the wall charger most of the time to 90%. I think I run around 313 or so with avg around 277 maybe.What's your efficiency and charging habits? I see you're in Florida so it's not like you're driving in the freezing cold.
What model do you have? Long range?My almost 4 year old model 3 has battery degradation of 14.3% according to the Tessie app. in the little graph they show it shows me well below the fleet average. Is this somewhat normal for people or is my battery way worse than most?
236rmi @90% implies 262rmi @100%Perfomrance. 64.4 usable capacity. 75.2kwh I don't know for sure, but I think around 262 or so at full charge. Now at 90 its at 236. Used to be like 260 when I got it at 90. That was about 20K miles ago and 7 months old.
64.4 is quite low. The ramge numbers support that as well.Perfomrance. 64.4 usable capacity. 75.2kwh I don't know for sure, but I think around 262 or so at full charge. Now at 90 its at 236. Used to be like 260 when I got it at 90. That was about 20K miles ago and 7 months old.
In short, the battery is melting.I am in Florida, I have had it since 7 months and just under 11000 miles. I charge to 90% almost always with wall charger and usually plug in whenever I get home and pull in the garage.
The initial capacity is not always correct, most often below the normal initial capacity, like showing 75 kWh or do on the 77.8 kWh old model 3 pack for example.Why so many questions about deg from Tessie app users, lately? Is the app doing something odd in displaying deg?
If you degrade i to >30% you only will get a new pack that is guaranteed of holding up to max 30% degradation the day the car is 8 years.So I guess I should just charge to 100 every day since the damage is done? No sense losing capacity to keep the battery in good shape. Any ideas on how to get it to Tesla ridiculously low 30 percent?
Show us a screen capture of the graph please. Two, normal and zoomed.My almost 4 year old model 3 has battery degradation of 14.3% according to the Tessie app. in the little graph they show it shows me well below the fleet average. Is this somewhat normal for people or is my battery way worse than most?
Its not that bad.I did experience similar degradation, LR RWD 2018, max range shows 281 at 100% and is a bit below fleet average, I routinely charged to 90% and accidentally left battery at 100% overnight on a few occasions while traveling on road trips and after returning from them while leaving max charge set to 100% so while I cannot say I abused the battery I have not been cautious with it either.
