taimurasad
Will be also great if you could also share some steps, tips or precautions to take when physically changing the part. Many thanks for your time !eBay. 2016 p90d model x
Free to access with account:Will be also great if you could also share some steps, tips or precautions to take when physically changing the part. Many thanks for your time !
Finally got the time to swap out the old pyro fuse to the updated version ... Side by side of old vs new fuse ... Part number that I used was 1111445-00-f
Even though my HV battery was replaced earlier this year, he said they wouldn't have changed the fuse.
I read is as they would not have checked if the fuse on the replacement pack was self powered and updated it during pack installation.@teedee - This is amazing!
The service advisor, the way I read it, implies (incorrectly IMO) that they used your old fuse off your old battery and installed it on your new pack that you received earlier this year.
But then in the invoice provided to you by the same service center (post#161), they are clearly (and correctly IMO) documenting the fuse installed on your new replacement pack "is an updated self powered fuse and no replacement is needed".
The fuse is separate from the HV battery.
I parsed it as independent data points.That might be, but note that he was trying to justify the charges for an updated fuse (the context of the conversation) and saying "The fuse is separate from the HV battery":
To me that implies he was trying to say they just changed the "battery" but not his old fuse and that your old fuse needs updating.
But, I do see your POV as well.
@Droschke I interpreted it the same way as you. I think the service advisor simply didn't know which fuse was in my car and was just trying to assert that the service was out of warranty. I felt like he had enough technical knowledge to sound credible but I don't think he was familiar with the fuse issue at the time. This was when I dropped off the car so no one had looked at it yet. Once they completed the inspection, the advisor called and told me the good news and there was no charge since it was their fault I got the false alert.The service advisor, the way I read it, implies (incorrectly IMO) that they used your old fuse off your old battery and installed it on your new pack that you received earlier this year.
Do you guys know if the technician writes the notes or is it the same advisor? Seems to be different people from my experience.
Techs are required to document their "narrative" they call it. Basically what they did and if necessary, how they got there.@Droschke I interpreted it the same way as you. I think the service advisor simply didn't know which fuse was in my car and was just trying to assert that the service was out of warranty. I felt like he had enough technical knowledge to sound credible but I don't think he was familiar with the fuse issue at the time. This was when I dropped off the car so no one had looked at it yet. Once they completed the inspection, the advisor called and told me the good news and there was no charge since it was their fault I got the false alert.
I do believe the written notes on the invoice since it is very specific. Do you guys know if the technician writes the notes or is it the same advisor? Seems to be different people from my experience.
The alert is on IC as well, if you receive it. Mine was there for two days in a row.It might have showed up at one time if I drove the car at the time when the alert was present and only that I did not drive the car during that time and then the software update had fixed it when I drove the car. Who knows.
there's pyro for 12v which will kill contactors n disconnect HV
I received the message as well and continued driving it for about a week on software version 2022.8.10.11. Received a software update to 2022.8.10.12. After the update completed the error message went away.I believe the tech writes it but the service advisor can modify it to fit the corporate guideline if necessary. They also use templates since the wordings on different service invoices have the same structures.
Either way, this episode seems to be self-induced confusion on their side. I've the same 90kWh/350v pack as yours but never saw this alert. It might have showed up at one time if I drove the car at the time when the alert was present and only that I did not drive the car during that time and then the software update had fixed it when I drove the car. Who knows. One thing I'm certain of is that the battery that you and I have came with the updated fuse on it installed.
Greetings from Ireland. Been lurking around and watching this thread with great interest as I've had this warning pop up last week on my 2017 Model S 90D (2016 build facelift car with the newer pack and the fuse under the battery pack). I've contacted Tesla and had the same experience as a lot of others on here, fuse is not part of the battery pack and therefore not covered under warranty, blah blah, pay up.The fuse was 50 dollars but you still have to have evfixme or someone that can go into the computer to reconfigure to the new fuse.
Thank you so much for this. Tesla is charging me $509.45, said the replacement would take all day, and also refused to provide a loaner car because they say I’m out of warranty. Though I’m in warranty for the battery, they are telling me that the fuse is external to it and not included in that warranty. I will have to take this to the BBB as their manager is refusing to cover this. I’m stuck here for 8 hours.View attachment 930628
UPDATE: Tesla ended up covering it under the battery warranty.
