Best Car Wax to put over 3M Paint shield?
Discussion in 'Model S: Interior & Exterior' started by bart513, Aug 15, 2013.
  1. bart513
    bart513 Active Member
    East Hampton
    I have a Roadster that was wrapped in 3M and I'm wanting to put a nice wax coat over that. Any recommendations?
    Thanks!
    BTW it was recommended that I post on this thread by TMC
  2. jerry33
    Texas
  3. bart513
    East Hampton
    Thanks Jerry! Much appreciated.
  4. kevincwelch
    kevincwelch Active Member
    Chicagoland
    My personal favorite is Collinite 845. However, I do not know if it contains any petroleum distillates.
  5. bart513
    East Hampton
    Thx Kevin. I'll check into that.
  6. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    #6 smorgasbord, Aug 18, 2013
    I like 3M 39030 Performance Finish Synthetic Wax, since it's made by the same company that made the paint armor I'm using, and was recommended by the paint armor installer.
    It's super easy to apply, which IMHO, is the most important thing. All waxes have about the same gloss and last about the same, so the one that's easiest to apply will get applied more frequently and thus look the best. I tried the Glare Pro recently, but am going back to the 3M.
    EDIT: My main reason for switching back is that Glare Pro leaves residue at the paint armor's edges, whereas the 3M does not. I don't want to spend a ton of time waxing my car, and the 3M is easier to apply. I might stick with Glare Pro for the trunk lid since that is the only panel without paint armor, but probably won't buy more when it runs out.
  7. Don from Jupiter
    Jupiter, Florida
    Does anyone have any experience with Liquid Glass wax? It is non-petroleum, and it gets rave reviews, but I can't get a clear answer as to its suitability with the protective plastic shield. Any thoughts?
  8. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    The instructions for my Protective Paint Armor were to use WAX, not some other shiny or abrasive chemicals. If you read the labels, and it says "Ingredients: Water, Wax" and that's all, then there you go.
    As Smorgasbord says, the one easiest to use is the one that gets used most often. My car is a year old with 30,000 miles on it and still shines like new, no swirls, no white residue. About the first thing anyone says is, "What a gorgeous car! I love the color!" So it's always waxed to show. I don't think I have ever had it LOOK dirty in all the time I've owned it except for going through the blizzard in Oregon.
    I use the 3M also.
  9. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    Most waxes on the market WILL contain petroleum distillates. Don't go by the label.
    You need to apply a nano coating if you want the most durable protection on the finish.
    Products like Opti-Coat, CQuartz, and true nano-products are the way to go. I'm not a fan of traditional waxes and sealants on the clear film.
    Also, the film turns yellow on its own due to the adhesive and UV rays. It's just a matter of time. The better quality films just take longer and the severity is less. But putting a hyper-coating like the ones mentioned above will help tremendously.
