After a thorough car wash, there’s still a dull area where the bird poop was dropped. Any suggestions? Thanks for your input.
The poop was left there for about 2 days. Yes it was under the sun for about 12 hours in that period.
I left it there for 2 day because I’d previously tried to wipe off bird poop as soon as I saw it but it would almost always leave some fine scratches on the spot. That’s why I left it there until the car wash.
If you think bird poop is bad, try spilling Coke on your paint.
You will find the answer with all your missing single socks.So I have a tree over my driveway, I mostly park in the garage but will sometimes leave the car out if I know I'll be heading out again shortly. If the car is in the driveway it gets covered in bird poop, but when there is no car in the driveway why isn't there a large amount of bird poop building up on the driveway
If you’ve removed all the bird poop and the paint is still dull, it is likely etched. Clay bars won’t help, clay bars are good for removing surface contaminants and they leave nothing but paint. Your problem is not that there’s something on the paint, the paint itself is etched.
Clay bars are minimally abrasive and the surface lubricant you use with them cause the clay to glide over the paint, contaminants stick to the clay bar so are removed. If you haven’t used a clay bar, you are in for a treat. You must keep them clean. A dropped clay bar is an immediate throw away, don’t even think of using it after you pick it up.
You need to get the surface smooth again. For that you’ll need a polish, which is a very fine abrasive, and you’ll need to polish out the etched paint. There are more aggressive abrasives, they are rubbing compounds, again some are for machine use. The polish is the finest in the abrasive line so is the gentlest for your paint. If you are unable to restore the finish with the polish, then a rubbing compound is the next step. Rubbing compounds are less abrasive than the very fine sand papers, so the rubbing compounds are used to remove very fine scratches left by the fine sandpapers. Rubbing compounds are safe when used by hand but they are still more aggressive than polishes.
You want a “polish” and not a wax product. Sometimes waxes are misnamed polish, probably because people use waxes to
“polish” cars. It isn’t a problem, just be aware of it. Get a fine polish that is made for machine application. And check the label, it should suggest applying a wax after use. With a polish you’ll be pretty much unable to damage your paint when you use it by hand. It’ll take a little while to rub out your dull spot. You must clean the area before using the polish. Any sand or grit in the surface will scratch the paint. The cloth has to be clean and free of dust or dirt as well.
You’ll just be taking off a tiny bit of the clear coat to get down to un etched paint. Once you have the smooth finish, you should apply a wax or polymer product to protect the paint.
This should get you back to where you were, a flawless finish. People use polishes with random orbit buffers to smooth clear coat and get that deep wet looking shine. Random orbit buffers are pretty safe. Professionals use rotary buffers which cut quickly but it is much safer for the hobbyist to use a random orbit buffer if one is inclined to use a machine. The rotary machines produce a lot of surface heat, they can rub though paint such as on the point of a metal crease. Random orbit buffers make this unlikely.
So steps;
1, clean the area
2. Apply polish with a damp cloth, rub out the etched part
3. If unable to get to smooth paint, get a fine rubbing compound made for machine use, use it by hand. Paint damage risk is extremely low.
4. If you cannot make the paint smooth with the rubbing compound by hand, then it’s time to seek a professional to machine polish the area. (Resist the temptation to learn to machine rub out your paint on your Tesla. Learn on someone else’s car, or an old car.)
5. After the paint is good, apply a wax or polymer
Once you master the hand use of rubbing compounds, there are all sorts of fine scratches you’ll be able to rub out. It’s well worth learning.
Man, much appreciation for taking the time for an incredible walk through. Truly grateful. Thanks.If you’ve removed all the bird poop and the paint is still dull, it is likely etched. Clay bars won’t help, clay bars are good for removing surface contaminants and they leave nothing but paint. Your problem is not that there’s something on the paint, the paint itself is etched.
So steps;
1, clean the area
