v12 to 12v
The over all vehicle shape does not seem that bad but the weird window shape does not sit well with me. Looks as if it's trying too hard to be different.
My oh my. BMW, what were you thinking??
Agreed. I believe this is just a computer rendering of the coupe concept, but it borrows heavily from the production version of the i3.I think this will be an important car for the industry, but I agree that window shape is just plane weird and I'm not digging that orange at all. Hopefully this will change by production time.
Seems like the designer fall asleep during the second falf of the car.
I like the Aztec look better.
tommolog said:It doesn't have a large hatchback area unless you fold the seats down, only ~ 7cu-ft. There is a front trunk also, but again it's small and can only hold about one grocery-bag sized item.
Here is the official number for the Leaf from Nissan's website, which states that is had 14.5 cubic feet of luggage space. This is with the rear seats up. I found another reference, which has 24 cubic feet of cargo space with rear seats down. I hope this settles it.evnow said:surfingslovak said:Isn't that with folded rear seats? Not sure about about the difference in EPA vs SAE rating, I will try to find out more.evnow said:EPA rates Leas as 20 + cu ft.
330 L / 28.31 L/cu ft = 12 cu ft (2012)
370 L / 28.31 L/cu ft = 13 cu ft (2013)
No, EPA number is behind 2nd row of seats.
I wonder if the cargo cover is the culprit.
Click to openTobias Baumann said:New car buying decisions more often than not factor in the capacity of the luggage compartment. Using modern CAD systems, it's only possible to compute continuous volume. However, customers typically like to pack a few bulky objects, such as suitcases or bottle crates, into the trunk compartment. For this issue there are two different standards used to compute usable trunk volume.
In Germany, and the rest of the EU, DIN 70020 is used. It utilizes small boxes sized 200 x 100 x 50 mm, and the requirement is to pack as many boxes as possible into the cargo space. In the US, SAE J1100 is used. This standard asks that boxes of several types and sizes are to be packed. In contrast to the continuous volume computation, this represents an NP-hard problem.
Until recently, car manufacturers used CAD systems to compute trunk space manually, which with time-consuming and inefficient. Trunk capacity is determined very late during the car design process. If it was known earlier in the car design process, this data could be used to adapt the design, and facilitate more efficient space utilization.
In this dissertation we present new algorithms to compute valid trunk dimension according to the US standard SAE J1100. We developed a software package, which can handle these three-dimensional problems. This software can process CAD input data and computes packings according to the standards mentioned above efficiently. As well, we integrated an algorithm topack arbitrary geometries into the trunk.
The algorithm is graph-based, and produces maximum weighted independent sets on a so-called conflict graph. This graph can be derived froma grid discretisation of the trunk space. We present a framework to eliminate a large portion of the vertices of a graph without affecting the quality of the optimal solution.
That is indeed very interesting. I found the reference for 24 cubic feet with rear seats down. It's on Nissan's US website. I looked at several other vehicles on the EPA site you referenced above, and their numbers were rarely in agreement with manufacturer data. That's very surprising, since SAE J1100 should be used for all officially reported numbers in the US.evnow said:This is what EPA says : 23.2 cu ft.
http://www.epa.gov/greenvehicles/Detailsresult.do?vehicle_ID=153381
