"Cabin Camera Unavailable" Kills FSD. AP Okay.
Guys I think I figured out the problem.
The problem is the ssd that is attached to the usb for the dashcam. I’m using a Samsung T5 SSD. After removing it, the camera issues stopped happening. I think the drive was either full or corrupted. Need to check it out.
But for now I’m back in business.
Can you all try this out too and see if it worked?
That is great that worked for you! As it turns out I have the exact same SSD, though the issue predates it.
I did have a USB hub plugged in back in december however that I still use. Ill try without both!
I had one too! I’ll keep you posted if it comes back today
Got into the car after work today and instinctively went into service mode to find there were no frame drops. I removed the hub but kept the ssd in.
So far no issues, ill keep you informed as well how mine goes.
If this was the fix we collaboratively royally overcomplicated this. Also guessing my service center may have made the issue about the harness up.
I put in a service request for the hell of it, Tesla service wants to replace the cabin camera and run a low voltage integrity check for $700. Ordered a revised cabin camera (PN 1098383-00-G) for $50 off eBay to install myself, I'll take the gamble and see if that helps at all. Already pulled the mirror trim to check for any loose/pinched connections and found nothing of note. Unsure if this will fix the issue but at least it's only $50. Pro-tip, if you're looking for one of these cameras used try looking for the rear view mirror trim piece with the camera already installed, they seem to be going for $50-100 used while just the camera itself seems to be going for more than twice that on most listings.
Reactions: Cyber_Kars
Also recently have been seeing repeat left pillar camera failures too which completely kills AEB and regular Autopilot, I pulled the pillar trim and checked all connections and did not see any issues. Tesla service didn't include replacing this camera in their estimate for whatever reason, only the cabin camera.
Aaaaand my camera died again. So there goes that theory. 😭
It did last longer before it errored out though. 🤔
I have a 2018 M3P with FSD and I have the same issue with the 'cabin camera unavailable' error killing FSD daily; sometimes even getting the additional 'autopilot cameras / emergency braking / visualization unavailable' errors as well. I saw your "fix" yesterday and gave it a shot by removing my thumb drive on my way to and from work. I definitely agree that it felt like it increased the time before eventual failure. My cabin camera error usually pops up within the first 5 minutes of driving, and I think I got close to 15 minutes before failure on my two drives. Seemed promising, but alas no luck.
I see no sign of any LEDs on my 2018 M3P, so I assume the revised camera is the one with the infrared LED emitters, correct? Does the updated trim piece include "windows" for the LEDs? Or is your suggestion for the combined trim+camera just based around ease of install?
Not sure on the infrared emitters but I will check when I get the part in. I just purchased the trim piece with the camera as it's way cheaper than just buying the camera itself. I also already have replaced my 2 repeater cameras as the turn signal bleed drove me nuts but even those drop frames occasionally and kill Autopilot... I hope at least replacing the cabin camera will make these errors much less frequent. We'll see.
I replaced mine already, it did not fix the issue. I fought them on it and my service center did a voltage test under the original diagnosis fee. $700 is steep to not fix the issue.
Reactions: brawndo
I have the same issue. Was driving last night and noticed FSD would not work. Went home and tested both our 2023 Model Y’s live cabin camera.
The car where FSD wouldn’t work looked like this at night.
My other Y looked like this in live view…
Do I need Tesla service to fix this? Night vision is busted in one of my Y’s.
If you only have the issue at night, yours is not the same issue. You may benefit from a camera replacement.
Just today I got the same error in my 2018 P3D, right after installing FSD 12.3.4.
Cabin camera unavailable. It works fine streaming from the app.
Tried the computer reset, no luck— I guess we’ll see what happens when the car goes to sleep. In the meantime, no more FSD for me I guess.
This is common problem regardless of what update your on. It happens to my 2019 M3 all the time. I was in the Middle Tesla shop recently and heard another owner complaining to the service advisor about this
Reactions: brawndo
Add me to the 2018 M3 club. It's been happening only with the cabin camera for about the last 6 months. Resetting DAS didn't help me. But then it will just randomly start working and stay working for about a month before cutting out again. Doesn't seem to correlate with any software pushes. The first time it happened I booked service using the phone app, and they scheduled me for the following morning at an SC hundreds of miles away. I asked why, when there are three SC's within a 40 mile radius of me. Never received a reply so I cancelled. I'm starting to believe it's more of a 2018 FSD CPU or CPU-retrofit hardware issue rather than a software bug, which would seem to have a wider gamut of model year owners screaming. Probably deemed too expensive for them to fix and they're just hoping we go away while pacifying us by saying a fix is imminent. The scant few reports I've seen from other model years that have posted may be due to a rare actual camera hardware failure.
I setup a service, and they want to replace FSD HW2.5 with retrofit of 3.0 and charge me $2500. I don't think that's a reasonable ask.
2018 M3 with the same issue. We paid for FSD a long time ago, but just did the upgrade from HW2.5 to HW3 last month. The car has never completed an FSD trip, and usually errors out within 5-10 minutes after engagement with the red steering wheel and take over immediately message.
Most of the time it says "Cabin camera unavailable" but on a couple occasions it has lost all of the cameras, and there is no visualization of the surroundings. I have tried a soft reset, which did nothing, but the FSD sometimes becomes available again, presumably after the car goes to sleep and does a deeper reboot?
I made a service appointment and they want $100 to do a "remote diagnosis". I asked why I need to pay for a diagnosis since I just had the feature installed and it has never worked since install (less than a month ago), and am awaiting a response.
