KenN
That's excellent data, with it being broken out so I can get an idea of charge needed for each leg, esp the long climbs! Thanks.
Despite not trying to, you've convinced me not to drive this car in severe conditions. I've already driven once when the Wh/km went above 300, for a not good enough reason AFAIK, so I'll just agree with Doug_G on the numbers. There are plenty of times I've been unable to make sense of them, in weather good and bad.
A question for the experts: For the first leg, 140km of rated range to go 87 km, I would think that means the Wh/km should be 1.61 times what it is for rated. Rated consumption is around 188, so that comes to 302 Wh/km for that leg. But the trip odometer showed 275 Wh/km. Can anyone explain why they are different?
No, I didn't stop anywhere on that leg of the trip, and I took a picture of the "since last charge" odometer just before I plugged in at the supercharger. There was a spike on the energy graph at the start of the trip, higher than it should have been for just driving. I see that pretty much every time I start driving in the winter, so I assume it's battery heating. On the weekend I was doing a lot of sitting in the car with climate control on (sometimes charging, sometimes not) for 30-60 minutes and then driving, and there was a spike every time. Maybe that's the missing energy. The disappointing thing is that the spike happens even if the climate control is on for an hour before starting, as it was in this case.Is it possible that you reset the trip odometer but did some heating before moving the car? That's the only explanation I can think of.
Yes, I was using max defrost (red icon) most of the time, and I even tried it once with Range Mode on, in case there was a difference. Doug's right - with max defrost on, the car gets too hot, but I was just living with that to try to get the window to clear.As for not coping with ice - did you tap the front defrost icon twice?
One thing I can suggest in conditions like that is to manually increase the fan speed. The Auto mode lets it drop too low once the cabin is at temperature, and as a result it can't keep the windshield clear even though the air is warm enough.
Seems like there was a missing test case in Tesla's winter testing: -7C, freezing rain, drive 80 km/h.
One other thought: as I cleaned off the car I noticed that the vents in the front bumper were almost completely blocked by ice. I could see that being a problem in hot weather, but could it be contributing here?
And BTW, if I had an autopilot radar there, it would have been totally useless under 1cm of ice.
I did check the fan speed a few times and it was at 11, but maybe it dropped lower sometimes. I'll check that next time.
Unfortunately Tesla doesn't provide any information other than total power consumption, so it's hard to understand exactly what is going on.
As this is a Cdn Trip planning site,has anyone have recommendations for Ottawa to Quebec City? May need to travel this route with Australian friends during August.
I have an 85 with dual chargers.There are several viable alternatives. However, it's hard to answer because the charging infrastructure landscape will be much different by then. Do you have a 60 or an 85?
For Ottawa --> Quebec City or points East, I recommend avoiding the Montreal island traffic, if possible.
1) If you have the CHAdeMO adapter, there's the Northern bypass: 50E to 15S to 640E to 40E. 442 km total. In Lavaltrie (234 km from Ottawa) Maskinongé (278 km) Yamachiche (297 km) and Trois-Rivieres (322 km) there are Circuit Electric 46 kW CHAdeMO stations where in 40 minutes you'll add about 160 rated km for $6.67. There's also an AZRA network CHAdeMO in Mirabal (166 km from Ottawa) that will do the same.
2) When the Drummondville Supercharger is open (work has restarted despite the Winter) there's a South-Shore bypass: 471 km. 417 to 30 to 20. The Drummondville Supercharger is at the 324 km mark. There is a small toll for the bridge crossing the St. Lawrence West of Montreal.
Once in Quebec City, there are luxury, well situated hotels (ALT and Germain) offering 80A HPWC. Or, there are hotels that offer clean rooms and 70A or 30A J1772 for about 100$ plus tax. (Repotel Henri IV and Cofortel). The latter ones aren't in business or tourist districts, but aren't too far by car, either. By August, it's possible the planned Supercharger for Levis (across the bridge from Quebec City) will be ready as well.
