Can't Summon
Discussion in 'Model S: User Interface' started by mileszat, Sep 30, 2016.
  1. mileszat
    mileszat Member
    Rochester, NY
    I took delivery (MS 60D) this past Monday. It took 3 days for phone app to work. When I press Summon, my phone reports that it cannot connect to my car, although all other features appear on phone. Any thoughts on how to get Summon to work for the first time?
  2. Saghost
    Saghost Well-Known Member
    Delaware
    Which app are you using on the phone?
    Some of the third party apps were broken by Tesla when they went to the continuous press version of the API.
    There are a few settings on Summon in the car's center console screen, and how you have them set may affect your ability to Summon as well. What are the settings currently?
    One you might want to consider turning off is the aforementioned continuous press - that requires the phone and car to be in constant communication, which might be a problem if either one has a marginal signal.
  3. kort677
    kort677 Banned
    florida.
    did you enable the summons feature in the car via the control screen?
  4. mileszat
    mileszat Member
    Rochester, NY
    Yes. I set the control to activate Summon and turned off the continuous feature.
  5. mileszat
    mileszat Member
    Rochester, NY
    I am using a Samsung 7. I get a message that my car cannot connect with my phone.
  6. mileszat
    mileszat Member
    Rochester, NY
    I have successfully change the temperature, so I know there is communication.
  7. 787steve
    787steve Member
    Cary, NC
    Were you on a level surface? Our car is also new, just a couple weeks. I can't remember the message I got, but I think it said Summon Failed. I realized the car would summon out of the garage, but not into the garage. Reading the manual, I found that it won't work on a sloped surface. Our garage floor is level, but the drive into it is on a noticeable up slope. Sounds like your message is different, but it could be a factor. Again, I can't recall the actual message. Like you I noticed that all other requests worked. Good luck.
  8. Saghost
    Delaware
    Is this with the factory Tesla App, or Remote S, or another app?
  9. idoco
    idoco Member
    Outside Philly
    You need to have location services on phone enabled.
  10. mileszat
    mileszat Member
    Rochester, NY
    It is factory installed and location on phone is on.
  11. EVie'sDad
    EVie'sDad Member
    Newark, CA
    Sometimes, with the release and installation of a new os update, i believe i have seen regressions where settings saved by me appear to revert back to their default settings, e.g. autosteer or summon needs to be re-enabled. Could this possibly be what you are experiencing?
    Check the settings from inside the car to see if that is indeed the case.
  12. mileszat
    mileszat Member
    Rochester, NY
    I will turn all settings off, turn back on and get back to the forum. Thanks
  13. Mknac
    Mknac Member
    Maryland
    Use the fob. Hold roof button until lights flash. Press frunk or trunk to move press again to stop the car.
  14. mileszat
    mileszat Member
    Rochester, NY
    I reset everything and a few hours later, the app on my phone connected. Thank you all for your help.
