Car flex and losing a roof rack with bikes?
Discussion in 'Model S' started by luvacoustic, Apr 18, 2019.
  1. murphyS90D
    murphyS90D Member
    Horsham, PA
    If the bolt is tightened down against the stop it is not going to back out. For 6/2015 and later cars the torque spec is 1Nm (8.85 in-lb). For 5/2015 and earlier cars, that use different hardware, the torque spec is 5 Nm (44.25 in-lb).
    An alternate method is to get a short metric (M6) stainless steel bolt, that is slightly longer than the depth of the threads, and a rubber washer. Put the washer on the bolt and run it into the threads until the bolt head tightly clamps the rubber washer to the bracket.
    I just noticed that my instructions say the maximum limit is 150 lbs, not 165 lbs.
  2. ArbitrageMan
    ArbitrageMan Supporting Member
    Northern Virginia
    I feel bad for the OP. This is scary on six different dimensions.
    The rust has me REALLY scared. My threads seem clean. Is filling up the threads with grease the correct preventative measure?
  3. murphyS90D
    murphyS90D Member
    Horsham, PA
    It's one way to do it. I mention another approach in post #61. Anything that prevents water. including very high humidity, from reaching the threads will work. Tesla, to my knowledge, has not said anything about the problem. I fear that the fact that most of the car is aluminum made them not think about rust and its prevention.
  4. brkaus
    brkaus Well-Known Member
    Austin, TX
    I’d think grease would be a mess. How about something like cosmoline?
  5. DARK_VADAR
    DARK_VADAR Banned
    Sydney
    Tesla design is junk , you never hear this kind of stuff happen to other cars
    • Disagree x 4
