Ah... That does make sense. But in my case they could put on the other side of the building near the drive thru and still have power pretty close but far from the walkup entrance. But not to the furthest part of the parking lot.J1772s are often close to the building because that's where the power is. It would be much more expensive to install them at a far away parking area. Superchargers are a different animal-- they need a new dedicated transformer so they can go almost anywhere.
wow, glad to be in ohio where the "average" cost is $0.116/kwh statewide and i've so far not even paid for any public charging DC Fast Included....In CA at PG&E rates they pull about $1.50 per hour average. At peak rates in the summer it can be double that. The rest is for site/owner profit, maintenance and Chargepoint profit.
I charge $4.00 per hour for my Eaton facility, but I deliver 70 amps instead of the Chargepoint's 30 amps.
You and @kort677 make good points here. The issue is cost, believe it or not.+1 re: airports installations.....c'mon, not that expensive & minimal electric cost.
FWIW: SW Florida is onboard with EV--both SRQ (Sarasota) & RSW (Ft. Myers...albeit not covered ) have chargers and given the concentration of EV vehicles in SE FL I don't understand why FLL & MIA don't install as well (FLL does have significant parking challenges though).
L1 "stations" cost next to nothing to install, usually the wiring is already in place, all that would need to be done is to install outlets at each parking stall, post signage and voila you have charging spots.You and @kort677 make good points here. The issue is cost, believe it or not.
More specifically, the issue is funding. Most EV installations at airports are funded by grants and there are very few grants for L1 installations. From an airport's perspective, four L2 stations are usually cheaper than ten L1 stations and they might even be cheaper than four L1 stations.
Not when each outlet needs to be on dedicated circuit.L1 "stations" cost next to nothing to install, usually the wiring is already in place, all that would need to be done is to install outlets at each parking stall, post signage and voila you have charging spots.
why would a separate circuit be needed? I'm not an electrician but usually installations in locations like a commercial parking garage are wired to a higher level than a home would be.Not when each outlet needs to be on dedicated circuit.
You don't have to be an electrician to understand why only one car can charge at a time, even if it's a commercial 20A circuit rather than household 15A. Every outlet needs to be able to supply the 15 or 20A. Simultaneously. That means separate circuits.why would a separate circuit be needed? I'm not an electrician but usually installations in locations like a commercial parking garage are wired to a higher level than a home would be.
Actually Teslas pull 12A from a 15A circuit, and 16A from a 20A circuit (80%) but your point is correct that one car uses the max capacity of one circuit.Tesla's and I assume other EV's can pull 15amps of power from a 120v outlet, thus making one car essentially the limit of what the breaker is capable of supplying.
