Charger error 1084 DMC FW: HCS Fault
Discussion in 'Roadster: Technical' started by Alan, Mar 17, 2015.
  1. Alan
    Alan Member
    UK
    Hi All,
    I have a old 30A charger for my Roadster(240V mobile connector 30A capable on the box) which has a blue 32A commando plug and a lunchbox sized box in the middle for the earth leakage trip / circuit to generate the pilot signal.
    It seems to have gone wrong - the lights around the charge port go red and on the VDS I get
    DMC FW: HCS Faulted warning
    ID:1084 Data:0x00800000
    Any ideas - inside the box its clean / dry & I have reset the earth leakage trip detect.
    Regards
    Alan
    PS If I can not fix it I may use the roadster connector and a type 2 socket to make an adaptor to use a Model S UMC. Has anyone done this - I am in the UK so can not use one of the CANs due to the different charge ports.
  2. Chillout
    Chillout Member
    the Netherlands
    Did you try lowering the Amperage?
  3. hcsharp
    hcsharp Active Member
    Vermont
    I don't know if you can use the EU spec Model S UMC with an adapter or not because I haven't heard of anyone who has tried it. I think you could make the adapter you're proposing if you had the right tools using your original Roadster cable. But it would be inherently unsafe. Remember that cable is rated for 32A (even though it only charges at 30). You have to assume that somebody will eventually try to use it with a 64/70A charging station. Meanwhile your 32A parts will be a fire hazard if somebody forgets or doesn't know they have to turn the amps down.
  4. Alan
    Alan Member
    UK
    Hi Guys,
    Lowering the amperage - tried that (10A) but same error.
    Cable rating - firstly the adaptor would be for my use but I will put a note on it in case it somehow got into the wrong hands.
    Used with the UMC or the charger at home it would see 32A max. The UMC is rated at 40A max. I need to check the rating of the existing cable going to the Roadster connector when I am next at home - its about 1 inch thick so unless its due to a protective metal shield the cable is at least as thick if not thicker than the high power Roadster chargers.
  5. Stefan T
    Stefan T Member
    Sweden
    I have get same error twice after the car was fully charged
    My clipper creek highpower wall mark fault
    and after disconecitng the cable to car and press the bottom stop on the charge it works ok aigin
    Anny ides what i shall try to with my charger or is it power supply problem the last time was my air compresor working and that is instllalled in same supply line but on all 3 phases
