WilliamG
If you set temp to max and have AC on for 30 minutes, you’ll probably use 12.5kW (maybe only 9kW), based on that other post here. So 4.5-6.25kWh, which is 19-27 rated miles for your LR AWD.
It definitely makes no sense unless you are going to start with 2500 feet of steep downhill. Seems like kind of a corner case! There’s 4kWh of energy to reclaim there so might just start to make sense.
Speaking of kW usage, I charge to 80% daily at home. The iOS Stats app will show me how many miles an hour I’m charging. I found that on my 60A circuit (48A actual) that if I set my charge % to 85% (for testing so the car starts charging) and turned the heat on to 68F (from 51F ambient), my actual miles per hour of charging dumped to 32-34. If I turned the climate off remotely the rate immediately jumped back to 44 miles per hour.
Friend of mine has a 30A in the garage and he charges his car at 22 miles per hour. Under the same test conditions his rate changes to 11 miles per hour with climate on.
