cali8484
Honda EU7000iS is a great generator but bulky and heavy which is probably a reason why it was left running in the shed. Switching to multiple EV's over the last few years I have seen many advantages over ICEV but after seeing some outages made me realize the downside of EV's during outages. I have since tested several generators for charging EV's during outages and Tesla is definitely more picky than others. In general, governor controlled engine generators do not work well consistently with Tesla as it's very sensitive to voltage level and frequency variations. Inverter generators generally work well for charging Tesla provided there is neutral-ground bond as others have pointed out. However, one challenge is that practical portable (i.e. carry in Tesla) inverter generators (e.g. Honda EU2000iS) only provide 120V output which does seem as efficient as 240V output for charging EV's in general. So, borrowing from solar/PV community, I tested autotransformer to get 240V split phase power from 120V inverter generators and it has worked well. Now I have a compact and portable EV charging backup power solution that includes a dual fuel 2200W inverter generator (<50lb), an autotransformer (<15lb) and mobile 240V EVSE (<5lb) that can be easily moved and setup anywhere. I chose dual fuel inverter generator because propane is cleaner which helps me feel less guilty about using and provides significantly longer run time. Also, if more power is desired then additional inverter generators can be added in parallel.
