Thanks @Cosmacelf ! I will try a replacement one - my local Home Depot doesn't stock it, will have to order online. Will report back.
BTW, in the 8 years I owned the house the old breaker never tripped with just the pool pump on it. Heavy downpours and all. My pump is plugged into a NEMA 6-20R, not hardwired (I bring it inside for the winter) It's an outdoor outlet with a metal cover flap (vs. Plastic enclosure) the outlet is in a 3 gang box and I can't find a plastic enclosure type cover for sale anywhere for the life of me! Appears only 1 and 2 gang ones are available.
Also, I read somewhere that the NEC codes don't require the GFCI breaker for hardwired installs - so your setup is definitely safe.
My pool pump doesn't have a GFCI. It is hard wired, not a plug, but no GFCI.
The problem most likely isn't the fact that it is a GFCI breaker, it is probably that the GFCI is just old. I suspect that a new GFCI breaker will work just fine with the Tesla.
