Hi all,
I thought I'd contribute the solution I'm planning. I'm trying to find the highest quality cable and connectors to make this as safe as possible. I have installed a NEMA 6-20 receptacle, fed with 12AWG copper wire and connected to a new 20A dual (240V) breaker.
However, the plug is a bit far away in my garage, so I need a 25 ft extension cord. There is a pre-made NEMA 6-20 extension cord that could be used with the Tesla 6-15 UMC adapter with no modifications, but I'd only get 12A charging:
Amazon.com: NEMA 6-20 Extension Power Cord - 25 Foot, 20A/250V, 12/3 SJT - Iron Box # IBX-6153-25: Home Audio & Theater
I'd need to chop off the NEMA 6-20R and put on a 5-20R to get 16A charging.
So, I might start with this 25ft cable which has a NEMA 5-20R:
Amazon.com: Conntek NEMA 5-20 20-Amp T-Blade SJOOW 12/3 Anti-Weather, Oils, Acids and Chemicals Rubber Extension Cord, 25-Feet: Sports & Outdoors
then cut off the plug and add a NEMA 6-20 plug:
Leviton 5466-C 20 Amp, 250 Volt, Plug, Straight Blade, Industrial Grade, Grounding, Black-White - Electric Plugs - Amazon.com
(In case anyone needs it, the corresponding Leviton high-quality NEMA 5-20R is:
Leviton 5369-C 20 Amp, 125 Volt, Connector, Industrial Grade, Straight Blade, Grounding, Black-White - Electric Plugs - Amazon.com )
I'm using a less nice solution now, but I've tested charging at both 240V @ 12A and 240V at 16A.
My efficiency data is as following:
12A 88.0%
16A 90.7%
24A 93.1%
and probably a smaller improvement when you go to 40A, but not by much. My data is from Teslafi and could be noisy. It is averaged over a few charging cycles.
So, getting to 16A is probably a good idea.
