eprosenx
I looked into that years ago. J1772 is a standard. Sadly it specifically does not support 277v. It would be interesting to see what would happen if a non-Tesla used a J-adapter... hmmm that might be what the DIP switches do... stop a J1772 car from closing the relay if the HPWC is connected to 277v.
I am pretty sure the point of changing the dip switch is to tell the HPWC that it will only find voltage from one hot to ground. The other hot and ground should be at (or very near) the same potential.
In 120/240 split phase it will be able to test potential to ground on both legs.
i.e. I am pretty sure it has to do with the GFCI.
On another random note, I don't understand why they don't support the HPWC on 120v. While it would almost never make sense to install one on this low a capacity circuit, it could have value to someone (at least temporarily).
I would not be surprised if you could flip that dip switch (same as for 277v) and wire it up at 120v and have it work (if my hypothesis on what that switch does is true). Since 120v is also grounded on one leg...
