MikeBur
ManualPilot
So, have few things to share re. excel files whilst we await Smac's automagic web site importer (see what I did there smac? ;-)).
I've hosted my initial captured data, as promised, as well as the excel source files in my attempt to help quickly create your own charts and visualisations. This Google Drive link is read only to all, and read/write to anyone wishing to copy these up (ie. just ask via. PM). The previous Lolachampcar sessions and mine are in sub directories.
In terms of using these, the battery one I created (MikeBur 02-16-2015 Battery Data.xlsm) should be the easiest. It presumes the ASCII output format of Bill's logger, just copy the data from the battery logging session to the first sheet (SourceData) and then you should have a static line graph for pack info and an animated graph potential to watch charging over time. Just press the animate button and the histogram will animate over each row showing cell voltage and battery module temp (and you can manually change the animation step rate for speed ). Note: to do this requires enabling macros in excel. Anyone can look at how dull my VBA code is, though if you'd prefer me to drop/post the source here and manually enter it just lemme know.
The second xls (MikeBur 02-16-2015-2230) is a little more involved, and is for the performance runs. It requires manually copying/pasting the data from each run, as there can be many captured in one session) into it's own sheet and then fixing up the range information in the calculated cells (after column "i").
The way I do this is copy a "Run" tab and then overwrite the first 8 columns from the logger session text file. Column 'K' appears to suffer the most as I decided to base everything on relative time and first entry being overwritten causes excel to go #ref tastic. Easy fix: cell K1 should read "=A2-$A$2" (without the quotes) and then sweep fill the column (select bottom-right corner with left mouse held down and move mouse down until you hit the end of data, then let go). This will generate the column data.
Next manual step is to enter your graph heading data and SoC, etc. from the log file. Currently this is at the end of each run, so I manual move this to the top right and paste the values in the appropriate spots (ie. Q2 to S2). After this I edit O5 and R5 for manual info - the graph title uses this with the min/max speed and Soc/Bat data to generate the titles.
There's a few other areas of manual prettifying, so don't hesitate to ask, make suggestions, or just edit and share back - no rights, guarantees, yada yada. Would love to see / hear what others can do with these, excel is not my forte and likely there should have been pivottables and the like, though they scare me ;-). Have fun!
Cheers, Mike
Cheers, Mike
