Ah, there are now three modes of operation-
Launch Mode
Fast Foot
Floppy Foot
Is the data file size not large enough to just save all the data once you enable perf mode instead of trying to capture something before it happens? When you want perf data you already know what you are going to be doing.
If you want a pre-trigger so you can catch TPS from 0, could you use some other CAN id (e.g. the turn blinker or the high-beam toggle) as the high-rate trigger? Like an interrupt where you just monitor CAN for the headlight blink which turns on the fast recorder--then stomp it...
the data overall I don't know what to do with those 2 data points...
Upgrade on Monday and then comparisons can begin
A few data passes with updated firmware-
Dropbox - HartP85D_0_60_2_22_16.TXT
Looking at some steady state speed where rear motor rpm and wheel speed should be static I get 118 (118.1742..) rpm per MPH. Using this ratio, Rear Motor RPM would indicate 2.93 mph before wheel speed moves off zero. 0.16 seconds elapses from initial rear RPM reporting until the car reports wheel speed. I am curious to learn if this is drive line wind up or a lag in the wheel speed reporting. Graphical analysis may provide clues with power consumption. Another way to look at it is the average Rear Motor RPM is 346 rpm/2 or 173 rpm. Multiply this by 0.16 seconds * 1 min/60 seconds and you get 0.46 wheel revolutions before wheel speed presents. This could be the sum of drive line wind up and the lag necessary for a few wheel speed interrupts to occur before wheel speed can be calculated and presented on the bus.
Looks like I got a 3.37 second 0-60 without roll out as well (as MikeB).
Change log
Added extra CAN message filtering to allow for capture of Rear Motor RPM
Replaced calculated Power with Rear Motor RPM
Provided header for SoC BatT and BatODO followed by the data on the next line to aid with Excel integration
Time TPS Speed R_Tq F_Tq BatV BatI R_RPM AWD
0111.48 085.6 +000.00 +039.4 +012.9 383.07 -0029.2 +00000
0111.49 100.0 +000.00 +089.0 +034.8 381.81 -0055.9 +00003
0111.50 100.0 +000.00 +150.6 +058.8 381.31 -0066.0 +00052
0111.51 100.0 +000.00 +206.3 +079.1 380.54 -0076.4 +00155
0111.52 100.0 +000.00 +238.6 +099.2 380.79 -0076.2 +00255
0111.53 100.0 +000.00 +235.8 +115.6 381.04 -0070.7 +00331
0111.54 100.0 +000.00 +199.6 +125.7 380.78 -0070.5 +00362
0111.55 100.0 +000.00 +170.5 +129.9 380.15 -0079.0 +00360
0111.56 100.0 +000.00 +155.4 +134.4 379.28 -0092.0 +00347
0111.57 100.0 +000.00 +178.8 +142.3 377.91 -0112.8 +00331
0111.58 100.0 +000.00 +230.1 +156.9 376.81 -0132.1 +00317
0111.59 100.0 +000.00 +270.6 +175.5 375.94 -0147.0 +00311
0111.60 100.0 +000.00 +300.0 +192.3 375.18 -0158.4 +00313
0111.61 100.0 +000.00 +316.0 +206.8 374.44 -0171.6 +00326
0111.62 100.0 +000.00 +335.4 +217.7 373.56 -0185.5 +00342
0111.63 100.0 +000.00 +354.3 +225.3 373.05 -0193.1 +00347
0111.64 100.0 +000.00 +372.2 +229.5 372.67 -0202.0 +00347
0111.65 100.0 +000.25 +387.5 +233.9 372.17 -0209.8 +00346
0111.66 100.0 +000.45 +398.4 +236.9 371.77 -0217.2 +00355
0114.97 100.0 +059.50 +185.1 +160.4 295.85 -1305.9 +07168
0114.98 100.0 +059.60 +186.0 +160.6 295.86 -1290.5 +07179
0114.99 100.0 +059.70 +186.0 +160.6 295.35 -1305.1 +07191
0115.00 100.0 +059.80 +185.1 +160.0 295.34 -1293.1 +07196
0115.01 100.0 +059.95 +183.8 +159.6 295.22 -1308.7 +07212
0115.02 100.0 +060.05 +183.8 +159.4 295.72 -1289.1 +07227
0115.03 100.0 +060.15 +183.2 +159.4 296.34 -1298.3 +07250
0115.04 100.0 +060.25 +183.2 +159.3 296.10 -1291.6 +07255
0115.05 100.0 +060.35 +182.5 +159.1 295.84 -1296.1 +07259
0115.06 100.0 +060.45 +181.4 +158.9 294.47 -1300.8 +07268
0115.07 100.0 +060.60 +179.5 +158.3 295.48 -1308.5 +07293
0115.08 100.0 +060.70 +178.8 +158.0 294.73 -1312.6 +07313
SoC BatT BatOdo
085.0 28.22 016115
Excel, though smac is working on an automagic way to import data. I find Excel strangely therapeutic - and I add more variables on the sheets to allow tweaking "easily".. yes, pita and likely some excel pivottable junkie could do this a lot more efficiently. Until then, feel free to steal / edit template from my google drive: https://drive.google.com/open?id=0BzwKZAn3p2LTVGRsdU9SMHpzUlk - this one is in LCC's directory, HartP85D.xlsx.
Ah Excel the swiss army knife of the IT world
Personally I'm using the built in .NET graphing functionality. I keep meaning to put some time in to port it to ASP.NET so I can get it publicly hosted . I think I have some unclaimed corporate Azure credits somewhere.
(Though as Kenny hinted at, I've recently bought myself a plasma cutter and a welder, so non IT projects and a break from my day job are getting a bit more focus right now :redface
Maybe 1300 Amps for 6 seconds is eating into the I2t margin of the main pack fuse--have to go back and dig that up later.
Interesting high-frequency limit-cycle in the R Tq during the squat on the uphill run.
Ask them if you can get a picture of the new fuse or write down the Bussmann part #, etc. so we can look up the curve for the new fuse.
Old fuse curve (630 Amp)
