Mike,
I love the overlays..... One graph says everything I need to know about the L upgrade. On average with an XYZ mile battery, these are typical results. Adding Bill's P90DL data to the overlay list will answer the 90 v. 85 question just as quickly.
As for roll out, I did an integration of wheel speed earlier in this thread to estimate when my MS had covered one foot of ground. The time to do so is in that post. I'll see if I can find it (along with the supporting logic for generating the number).
update
Link to roll out comment #2563
Looks like I found my car used 0.21 seconds to traverse the first one foot.
apache,
I look at things as having several ways to collect data. The wireless/hardwareless approach has its appeal. I was a little more interested in high resolution data as close to the source as possible which is why I looked into the chassis CAN logging.
We are on MS number 5 and I've been surprised to see that all of them have been either spot on or dithering on GPS speed at 60 mph. My experience with OEM speedometers in the past has had most all of them being over optimistic in their reporting (thus presumably over optimistic in the car's efficiency which is what I was investigating when I checked my spedos). When compared to the VBox, CAN wheel speed has the benefit of an order of magnitude higher report rate and will be more repeatable even if there is an absolute inaccuracy. The repeatability allows for very accurate back to back tests even if there is an accuracy issue that would prevent perfect 0-60 (and like) measurements.
Basically, the logger is but one more option for those looking to understand their cars.
On a different note, I've heard the argument on the HP thread about the larger spec motors being able to generate more low end torque even though overall power is battery limited. By the looks of all the graphs, Tesla is torque limiting both motors (those flat initial lines) prior to battery limiting kicking in (the torque knees). There may be bigger motors in MS but it would not appear as though Tesla is making using of the extra torque available at lower rpm from over spec'd motors. This can also explain why times are not improved on sticky prepped drag strips. The launch is not traction control limited but simply torque capped by the electronics.
If this is true, then we've probably seen our best 60ft times.
