SummerlinChiro
??? No data was adjusted. If there's no warming then why are sea levels rising? Science says it's mostly due to thermal expansion of the ocean. If there's no warming how are the oceans thermally expanding? If it's not thermal expansion what's causing them to rise?
If the tales of global cooling scared you then you must recall WHY they said it would cool... so... WHY did they say it was going to cool? Please explain.
Also.... how to microwaves work?
Sea levels have been rising steadily since the last glaciation, 3.4mm per year. Simple photographs from 100+ years ago show no major change.
Remember how the Maldives were in crisis because the rising oceans were going to swamp them? They are actually growing!
Why was Greenland green when the Vikings settled there when CO2 levels were much lower?
You can't answer that simple common-sense question...
You guys on here crack me up.
Scientists are supposed to be skeptical! They sailed through the Northwest Passage in the 1850's, early 1900's, etc. That means no ice!
They thought it was going to KEEP COOLING because there was a major cooling trend from the 30's to the 70's, and humans with their limited sense of scale tend to think whatever is happening now will keep happening.
Why are the temperature "adjustments" counter to the UHI? Explain that!
Bad stats are bad stats, no matter the discipline. You can't just stupidly accept the claims of NOAA that they are measuring global temps to .01 degree of accuracy with data that is close to 50% "infilled" (aka "made up").
This is NOT good science!
Speaking of science, let's talk about modeling. The furthest that modeling can take you is to a hypothesis. Modeling is just made up numbers in a computer program. You can fiddle with it to get any outcome you want. Climatologist confuse modeling with the real world. I have a engineer friend with a PhD in modeling, he laughs at the climate modeling papers.
To summarize:
Not too long ago, Greenland was GREEN when CO2 levels were LOWER.
Life exploded on the planet when CO2 levels were more than 10X higher, this is when corals evolved.
The best temperature data over the last 120 years shows NO WARMING over the last 120 years - until you "adjust" the data, (which is what happens when you put true believer fanatics in charge of the database!)
We are actually in an ICE AGE, but luckily in an INTERGLACIAL period of the current ice age.
There is a much greater likelihood of having a true glacial period or a "little ice age" that harms humans rather than overheating.
Climate scientists have EXTENSIVE record of apocalyptic predictions than never manifest.
They also deliberately mislead by omitting data that doesn't advance their narrative.
This graph here is the smoking gun for outcome bias. Real world science numbers never correlate so tightly.
