Connecting to wifi
Discussion in 'The UK and Ireland' started by Aviator, Aug 29, 2016.
  1. Aviator
    Aviator Member
    UK
    Has anyone else had any issues connecting their MS to BT wifi at home? I've tried at both our houses (both running the latest BT Home Hub) and the car simply won't connect! I can see the networks, but when I enter the wifi password it tries then fails to connect.
    Any magic tricks?
    Thanks,
    Dom.
  2. WannabeOwner
    WannabeOwner Active Member
    Suffolk, UK
    From memory I had problems with my (non BT) WiFi too. I put the password in ... nothing ... tried a few times, gave up ... then the next morning found that it had sorted itself out. Probably no help in your situation, as sounds like you've tried two locations presumably? over a somewhat prolonged period.
    I presume you can park close enough to the WiFi to get a decent signal? I suppose if your phone gets WiFi signal where you park that would do as a test (I read that the Car has much stronger "latch" onto WiFi than phones, but that's a second-hand length-of-string anecdotal comment!!)
  3. PaulusdB
    PaulusdB Mayor Gnomus Vintage Limb
    Europe
    You should force your BT router to provide access to the car on a 2.4 GHz channel from 1 - 10, if possible.
  4. markn455
    markn455 Member
    Ball Ground, GA
    I never had any issues connecting with WiFi at home until about 2-3 weeks ago. Around the time I got the .100 update.
  5. Buddy
    Buddy Member
    Riverside County
    Unable to connect to my home wifi also.
    Can some elaborate how to "force" - connection? I'm not familiar with this subject.
