I don't know where these guys got my email address from but, do we know these guys? They seem familiar.
Dear Michael,
I'm writing to introduce Convergent Power, Inc., a company formed to manufacture electric motors and generators for use in the industrial, transportation, water/waste, and electric power markets.
The Company has developed a Synchronous Reluctance Motor which employs a geometrically modified rotor that recaptures normally wasted energy and applies it to the production of work. The rotor geometry, in combination with a modified magnetic circuit, enables the motor to convert electrical current into mechanical torque while reducing the amount of back-EMF produced, demonstrating that back-EMF can be managed in the same way as eddy current and hysteresis losses, as it is in fact a parasitic parameter. Consequently, the motor operates at lower source voltages, substantially reducing the amount of power required to produce a given horsepower compared to conventional machines.
The motor operates as follows: A reluctance torque is created while maintaining a constant air gap, thereby reducing the armature reaction produced by conventional geometries. This is made possible by the fact that most of the magnetic potential created in a gapped magnetic circuit establishes itself within the air gaps, and as long as the gap dimensions do not change in time, back-EMF is minimized, allowing the creation of a torque that is proportional to the square of the flux, and the rate of change of reluctance with respect to the change in time. Then, by resonating the inductive reactance in the windings, the motor is operated at lower source voltages relative to a given output than conventional motors.
The Company’s generators employ similar design principles to produce output currents while reducing back-torque. As result the generator requires a smaller prime mover, and consequently requires less fuel to produce a given output than conventional generators.
After eight years of internally financed product development, we are offering shares in the company in order to capitalize operations. If you would like to learn more, we would be happy to forward a powerpoint and related documentation, as well as answer any questions you may have.
Thank you in advance.
Chris Daniel
T: 310.562.9308
[email protected]
www.convergentpower.com
