I suspect that some Tesla service centers (or individual Rangers) will be willing to swap pads, perhaps on the QT. That is a trivial and very safe modification.
I doubt any would take on rotors.
At this point it would be more of a distraction, but possibly in the future after these have rolled off.
Thanks Adiggs!
So I have the following who're committed to the rotor set:
-Hcsharp
-Tobash
-Dsm363
-Adiggs
-Wiztecy (me)
Anyone else? Once these are being made its a done deal and I'm sure we won't be making any more hats. We can however have more disc's needed as they need to be replaced.
Honestly, this is the best place to put your money. When it comes that you can't brake in time, its done and the damage easily will exceed the cost of upgrading your braking system.
Also these rotors should remedy the rear warped rotors of setting / pulling the emergency brake when parking the Roadster while the rotors are hot.
Lastly look at the benefits of having a reduction in "unsprung" weight, the weight we're saving by making the hats aluminum. Some benefits are better response from the suspension since less weight has to be dampened as the wheel comes up, improved acceleration and braking since the rotating weight has significantly been reduced.
Hi Wiztecy - put me in for two sets!
Thanks for putting this together,
-Jonathan
As someone who recently purchased the extended service agreement I would be hesitant to purchase these at this time. Wiztecy always has amazing information on improving the Roadster and I would go in if it wouldn't violate the ESA.
Thanks Tobash!
Also added Roadster08 to the list.
Special Thanks to Adiggs who took his time to meetup with Dave the Fabricator who needed to measure the rotors for the project. Will update once we get new status.
Adiggs/Wiztecy: Do you have the measurements of the rotors? From trying to find an aftermarket replacement rotor, I believe there is the possibility that the Roadster uses the same rotors as a Saab 9-3 or Pontiac Solstice/Saturn Skye. These have a 5x110mm bolt pattern and Brembo has a nice online catalog with dimensions of all their available rotors. Another possibility is the Opel Speedster. I have included a diagram of the rotors for a Speedster to see all the measurements that Brembo has.
