Custom Sounds -
Lots of talk about custom lock sounds, but the instruction on the car screen indicates that you can add up to 5 custom sounds that can be accessed by means other than the lock sound. I added two sounds under boombox and they are not showing up anywhere. Help
From the manual:
Prepare a USB drive for Boombox​
Follow these steps to add up to five custom Boombox sounds:
  1. On a computer, format a USB drive to exFAT, MS-DOS FAT (for Mac), ext3, or ext4 (NTFS is currently not supported).
  2. Create a folder on the USB drive called Boombox.
    Note: The USB drive can only contain one folder. For example, it cannot be shared with Dashcam.
  3. Add .wav and .mp3 audio files to the folder. Although you can add as many files as the USB drive's capacity allows, you can only select from the first five, as listed alphabetically. File names, of any length, can contain upper or lower case alpha characters (a-z/A-Z), numbers from 0-9, periods (.), a dashes (-), and underscores (_).
  4. Plug the USB drive into a front USB port.
  5. Choose a sound from the USB drive by selecting from the Boombox dropdown menu.
Note: The custom lock sound is handled differently and there can be only one, but it doesn’t sound like that’s what you want.
Upvote 0
