We, America, need DC lines from the west coast to east coast. Personally I don’t care if they are owned by the feds. It just needs to be part of the move to sustainable energy.
2. If so, what problem do you try to solve ?
I suspect that what you may try to recommend would be to transfer excess of solar energy from the west coast to the east coast because the east coast will be already in the dark
It's almost always good for renewables somewhere over a large area. Still (wind), dull (solar) days are rare over a large enough area. Overbuilding renewables with some storage is likely to be cost effective (Tony Seba). Sunny west/east coasts at different times extends solar generation window.1. Can you clarify what you call "DC transmission lines" ?
Do you mean:High-voltage direct current (Wikipedia)A high-voltage direct current (HVDC) electric power transmission system (also called a power superhighway or an electrical superhighway)uses direct current (DC) for electric power transmission, in contrast with the more common alternating current (AC) transmission systems.
I suspect that what you may try to recommend would be to transfer excess of solar energyfrom the west coast to the east coast because the east coast will be already in the dark?DC high voltage has some advantages over AC high voltage but is also more complex and costly to implement:Converting from AC to DCThe challenge, however, is that to transmit via HVDC, two converter stations are needed. First, the AC power must be converted to DC to begin the transmission process, and then when it gets to the desired tie-in destination, the DC power must be converted back to AC to be utilized on the grid.
Transmission helps; batteries help. But you really need to talk to South America and get transmission lines built from there too.
Anyone with solar and all electric knows the real issue is the shorter days and colder temps in the winter. And that impacts all of the US at the same time and there is no realistic battery to fix that. Hydro from the pacific NW might help but those WA folks are not going to be happy about paying 5X for electricity. The hydro is not scalable. So spreading it out all over the US in the winter will be quite challenging. There is of course hydro in Canada/Niagara but that has the same issue of not being scalable.
Yes wind certainly helps. But converting all heating to electric will take a very large amount of wind to power. Not to mention the cars with less efficiency in the winter. And trucks with worse aerodynamics pushing cold air. It is a lot of power.
Seba - 70 MMB/D by now. We did 101.7 for 2023 - the highest ever. He is way too optimistic. We have to build 20X what we have today just to reach parity and 40-60X to overbuild. That also is neglecting all the energy it takes to build the batteries (and the wind and solar and transmission lines).
Also, we have known we need transmission lines improved for decades. And where are they? Our system of government doesn't allow for that much regional cooperation not to mention the environmental impacts and reactionary states blocking things. We have 1/2 the states banning cities from banning natural gas and you want them to cooperate to build transmission lines?
Sunzia - 10 years or 12 years or maybe 15 in the making. $12B for ... 3.5 GW. That is .5% of US electricity use or about .15% of total energy use. So multiple that transmission line cost and time line by 100 to get an idea of what we need (that would be to transmit 15% of total energy which is very optimistic that this is all we would need). It is also just 550 miles, through some of the most empty areas of the country, when to cross time zones, you need 1000s of miles.
We don't have the government structure to accomplish this. We are nowhere near the public opinion to change the government structure. That is the real problem. This is no longer a technical or economic problem, it is a government one.
Maine's solar resources in December are 50% of the resources in July. If there's a challenge it's that you'll probably want a more vertical angle. So, best economics probably just means build a higher multiple.How many other countries have 50 parts with diverging economies, motivations and ideology. Party policies are partly a reflection of that which is a reflection of our structure.
It is hard for the federal government to force a landowner in Kansas to allow a transmission line over his property. The number of property owners is quite large and getting 100% is not going to happen. This is structure.
There is enough solar resources to do anything. But sun hitting the ground is not the same as the infrastructure to capture it. A 50% drop off in solar is partly because most solar is built in the southern part of the US. Build it in the North and the drop off is worse.
Almost every part of the country has less efficient driving and trucking in the winter even if they don't need much heat. But the majority of the country needs to heat their homes and office buildings.
We can't make this work with our current government structure. We obviously can't have consensus with out current structure.
