Deleted destinations reappear instantly
2023 Model 3. Version 23.6.9
I press and hold and click the x to remove the address. It reappears after a few minutes or if I navigate away and come back.
How does one file a bug report or make Tesla aware? There seems to be no fix.
If I were to reset the car, assuming I have to program all my keys again or am I locked out?
There’s no good way to file a bug report that goes directly to Tesla. The problem will likely get resolved since it seems like a new bug, but try rebooting if you haven’t already.
A factory reset will erase all your settings, which seems a bit drastic for solving this problem. A reset won’t delete your key cards, but you will need to set up your phones and everything else again (including HomeLink if you have it).
Upvote 0
I think the voice-activated bug report still works. Press the "Voice button" (right on the steering wheel. Then say "BUG REPORT" and follow with a short description of the bug. I assume it works as it still listed with voice commands that are understood.
Those bug reports don’t go anywhere. They take a snapshot of your car’s state that can be used by Service if you have them check the car.
Upvote 0
I've always imagined the bug report feature works similarly to the pneumatic tubes on Lost.
Reactions: RayK and BitJam
Upvote 0
If this is only really occuring on a single vehicle, then it's not really a "bug". It's an individual problem with a particular vehicle. Let it sit a couple days, see if it goes away. I know this doesn't make a lot of sense, but it's worked for me before. Sometimes the issue just resolves itself.
Upvote 0
