CrazyRabbit
You can use propane heaters indoors, I have two Mr heaters…. I only get 8-12 kWh on the worst days, but I get +100kwh with a sunny day in winter.
Additionally, ventless propane heaters put a lot of moisture in the air. I've had water puddling in my window tracks from the condensation in my camper.You can use some propane heaters indoors, at least until the oxygen level drops. Even the Mr. heaters come in several versions, not all of which are safe for indoor use.
Is Mr Heater Safe Indoors? (Yes or No) | ValidHouse
Is Mr Heater Safe Indoors? Not all Mr Heater products are safe for indoor use. Outdoor Mr. Heater products are not safe indoors to avoidvalidhouse.com
All the best,
BG
I understand the moisture issue becomes larger in a smaller space. I'm not anticipating that with 2400 ft2 space.... but may also add a vented stove depending on how well things are working after a season's experience.Additionally, ventless propane heaters put a lot of moisture in the air. I've had water puddling in my window tracks from the condensation in my camper.
I welcome the added moisture, my house gets way too dry inside in the winter. So that is a benefit and I already new it.Additionally, ventless propane heaters put a lot of moisture in the air. I've had water puddling in my window tracks from the condensation in my camper.
I really want a catalytic wood stove insert…. They work really well.I understand the moisture issue becomes larger in a smaller space. I'm not anticipating that with 2400 ft2 space.... but may also add a vented stove depending on how well things are working after a season's experience.
I deleted two chimneys during my Solar Roof install - they were metal chimneys, on a couple of manufactured wood burning fireplaces. I guess I've been done with cutting and handling firewood these days, and the location of the chimneys was such that I was able to get additional 5-6 kw of rated capacity out of my design along with eliminating some shading without them. Of course those chimneys wouldn't have been code or insurance requirement compliant with wood stoves, with or without catalytic.... It wasn't an easy decision to turn toward propane, but reality and feasibility conspired to make that a possible way to reach a fairly significant goal. And additional moisture that time of year is welcomed, I run a humidifier on my heat pump that almost gets me where I want to be with moisture in the winter. My possible vented stove option will depend on how much value I can see in making up for annual kwh gap worth of BTU, perhaps resulting in the ability to find a credible off- grid indefinite operating path. I am envious of your 8 Powerwalls..... I've got 3, and may opt for another one ot two myself instead of going for an additional propane burner. Gotta see a full year or better of operation first.I really want a catalytic wood stove insert…. They work really well.
Today was heat pump day (5.5 tons of 'um). Gone will be the 1500W steam unit, run ~3hr/day just to get to ~35-40%RH. Those losses came with the home's 154k btu oil unit. Cruising TMC tonight 'cause I need Winter power! Off Grid? Pffft.I welcome the added moisture, my house gets way too dry inside in the winter. So that is a benefit and I already new it.![]()
Yes.... I stopped burning wood some years ago, for some of those reasons. Pellets don't get rid of all of it, still gotta move the wood. Much like corn. I was a corn man for a while as well.....carried a lot of corn.For those considering wood stoves you need to factor in the amount of work involved. I use a soapstone catalytic wood stove to supplement my natural gas furnaces. It's beautiful and wonderful to sit next to BUT I'm chopping and storing wood a lot, the stove and surrounding area needs to be cleaned frequently (including the chimney), and the stove needs to be tended to hourly to keep producing heat. It's way more convenient to have a thermostat. They do make pellet stoves that are more user friendly, it's not as pretty but probably easier to live with (although it does need some electricity to work). Nothing is perfect.
Wood warms you 7 times.Yes.... I stopped burning wood some years ago, for some of those reasons. Pellets don't get rid of all of it, still gotta move the wood. Much like corn. I was a corn man for a while as well.....carried a lot of corn.
I used to like that part of it..... wood has warmed me many times, as has corn, but not nearly as much. But I ended up moving on I guess. These days wood still warms me, but not in the same way - I put strings on it, and warm myself with them. Hopefully I warm a few others as well!Wood warms you 7 times.
When you cut it.
When you move it the first time.
When you chop it.
When you stack it.
When you move it again to the stove.
When you burn it.
When you clean up the ash and bark chips and dust the house.
What could be better?![]()
supplementing with fire place, and on a good solar day I can generate 80 kWh in winter, summer 130 kwh; but I can’t count on solar in winter. If I shutoff the electric resistant heat I probably could.
I would like to toss out my existing hvac, but for a few week out of the year it does what it needs to within my energy budget (solar production). To replace three systems would be expensive, $30K plus. I will keep fixing what I have, I do my own work.fireplace or stove? If it's an open hole in the wall with a chimney you're likely removing more heat from your house from convection than you're adding with radiation.
'Resistance'? Why no heat pump?
You can get panels regularly now for ~$0.30/w. I've started mounting them vertically. They don't take up ~any additional space but really kick butt in the winter. Any E-W fence covered in south facing panels with good exposure would easily cover winter use.
I have regular fireplace insert with glass doors, I was able to get the living room up to 70F during URI, so it dose work. I fully understand your point. But now I got Mr. Heater’s, propane.
Vertical panels make sence with large snow fall, especially if up north.
Still have a few more days left in November…. Solar for the year.
My insert has fresh air inlet on the sides, Glass helps slow the flow up the chimney.A fireplace will usually warm the room it's in but will cool the house overall since it's sucking in air from exterior rooms which is obviously replace with cold outside air. That's why wood stoves are so critical, they control the airflow.
The premise of the vertical panels is more to just take advantage of unused vertical surface area, especially when you just need more production in the winter.
Why not add a few heat pump mini splits. They would probably pay for themselves in ~2 years if you DIY. You can usually find 2 ton units for ~$2k. That would save a couple gallons of propane per day.
