No, it is a property of current battery technology. BTW, even ICE's can damage from the gasoline degenerating chemically.
As has been pointed out in the blogosphere, gas going stale in a car isn't going to cost $40K to repair. And, that takes a lot longer than a few months.
It was more than misleading. TopGear has crossed many lines, in many episodes not just regarding Tesla. (And Tesla did a lot of Roadster events.)
A court of law said the Top Gear episode was
not misleading. And that wouldn't have happened has Tesla not sued. All Tesla did was legitimize Top Gear. Again, this was a bad approach to the problem. You and I know the truth, but steadfastly sticking to it is almost never the right PR move.
It seems pure speculation that Tesla could do something in a recall. The problem is not new to them, and without discussing things with their experts, we have to assume that they chose the best solution for a range of possible situations.
Clearly not the best solution, as they improved the design in later versions, as well as in later cars.
"Prevent" is asking for an absolute that can never be fulfilled.
OK, so I should have said "help prevent."
You can't protect everyone from their own stupidity.....
The following
pic shows a major fire risk for all ICE's...should the manufacturers issue a recall notice to prevent it ever happening again?:
Yup, it's a design problem. The car designer put the filler pipe in the wrong place, if it was at the rear of the car you could drive away and the nozzle would fall out. Or there could be a sensor on the fuel filler door that prevents the car from starting when it's open. Someone should be blogging about this!!
Well, first of all, I note that the hose had a breakaway connector. These were retrofitted onto all gas pumps (at least in CA) at some point. So, that's the equivalent of a recall.
But, note there's a big difference between stupidity and ignorance. Putting the hose in your car and driving off without remembering to remove it is stupid (or at least forgetful). Not knowing that your car can't sit for 2 months without being plugged in is ignorance.
What's ironic here is that the Roadster tells you if you attempt to drive the car with the charge port door open. Imagine driving off with the connector still attached and live wires breaking off!
