I caught it last night running its cooling system when I hadn't prodded it, so apparently it periodically stirs the pot in hot weather.
You're assuming that battery decline is linear with time. In fact it's not. Li-ion cells generally degrade much faster in the first year and then lose capacity much more slowly after that. An 8% decline in 2 years would be more consistent with 80% of original capacity in 8 to 10 years.I would call 1% insignificant. I'd call 8% (down to 173 from 188) significant. My understanding is that "battery lifetime" is generally used to mean the time it takes for a battery to degrade to 80% of its original capacity. I'd think that a decline of 8% in 2 years is a lot. It would suggest a "lifetime" of 5 years, compared to the seven years Tesla has recently suggested. OTOH, for many people even a 50% decline would still be adequate. For others, a 10% decline would render the car unable to perform as needed.
If 4% per year is the norm, that's still over 10 years. (One of the reasons I think I'd have been less happy with a Leaf is that it has too little buffer for battery degradation.)
0.5 what units? One half of one percent? 0.5 km? 0.5 KWh?...
The other day my Ranger said my battery was in unusually good shape for a 1 year old. Down only 0.5. I imagine the Ideal Range number will eventually start going down as the battery ages.
You should tell us more about that. Where do you keep the car, which temperatures are there, how many range/performance charges, do you plug in every time you can, how many miles did you drive, are you an aggressive driver etc. etc. etc.? :wink:
Many thanks. You seem to be similar in behavior as me. Hope my battery will keep up as well. The only thing I can't do is driving the car everytime the charging finishes. How do you manage that if you plug in daily?
My ideal range dropped from 302 km to 298 km and I have 2500 km on the odometer.
after more then 35.000km i still get 304km when charging with 10A only. with 32A i got 293km only.
Haven't we been told that occasional use of Range Mode is actually healthy for the battery? The rumor I heard was that Tesla went overboard warning us all about how Range Mode reduces battery life, and then they weren't getting any field data on Range Mode because nobody was using it. The word on the street is that service was instructed to charge vehicles in Range Mode whenever they were in for service, just to get more range data (I find that hard to believe, though, since such a practice would have customers leaving the shop with no regen braking available and that could be a really bad surprise for someone).I found that after each of my road trips where I put the Roadster in range mode and then ran it down (in a single trip) to within 20 miles or less range left, the ideal miles in standard charge mode would climb by 2 or 3 to get up slightly over 190, usually 191 to the previous 188 or 189.
I am wondering if my battery pack may be degraded after reading these posts. Typically after charging in STD mode I see 150 miles of range. Thsi can bve as low as 125 if I have been hot rodding it or 165 if I have been driving conservatively but I have never seen above 165 miles ideal range in standard mode or 266 KM.
I was under the impression that battery balancing is a totally passive phenomenon, where active charging is unable to force the exact same voltage across every parallel group of cells, but once charging stops the higher-voltage cells charge the lower-voltage cells until they match closely enough that current stops flowing. Granted, only the groups of 69 cells that are connected in parallel would have this passive balancing, or 'settling' as I heard it called.I was told that a little bit more battery balancing happens after a range mode charge. I could see how that might possibly help a little, but who aside from Tesla's drive train rngineers really knows.
