Tesla Model S Door handle failures have been an issue for as long as Model S has been in production. There have been several revisions over the years but ultimately they still fail for a number of reasons.
Gen 1 used a pressure sensor to "sense" when you pulled on the handle grip and these were the first thing to fail.
Part #'s
1007372-00-A-G RF Gen 1
1007373-00-A-G LF Gen 1
1007374-00-A-G RR Gen 1
1007375-00-A-G LR Gen 1
***Most Gen 1 Handles do not have any part number tags/stickers on them.***** Ribbon cable coming out of module and lack of 3rd microswitch is best way to identify these.
Gen 2 changed to an additional microswitch instead of pressure sensor. Because the switches are on the moving linkage the stiff wire and brittle insulation tend to break or crack allowing in moisture and breaking the circuit. The Paddle Gear is also made of cast metal and the ears of the gear break off of the shaft and the door handle no longer presents.
1007372-00-H-L RF New
1007373-00-H-L LF New
1007374-00-H-L RR New
1007375-00-H-L LR New
1030273-S0-A/B LF Reman
1030274-S0-A/B RF Reman
1030275-S0-A/B LR Reman
1030276-SO-A/B RR Reman
Gen 2.5 saw a new handle "chassis" but the same design for the microswitches and paddle gear. The only benefit is the handles "chassis" were no longer specific to front or rear doors just specific to Left or Right however modules were still location specific. The door shells themselves physically changed to accommodate the new style handle. (ex. LF handle couldn't be used as a LR even though it would physically bolt up)
1071881-S0-A RF New
1071880-S0-A LF New
1071884-S0-A LR New
1071885-S0-A RR New
Gen 3 Cars were made after 7/24/17 deleted the microswitches in favor of a hall effect sensor, separate module, plastic vapor barrier and updated paddle gear design (still cast metal). The module seems to be the weakest link with this design but hasn't been out there long enough to say otherwise.
1100299-S0-A LF/RR New
1100300-S0-A RF/RR New
The overwhelming majority of people fall in the Gen 2.0-2.5 category. For these door handles we have designed a Stainless Steel Machined Paddle Gear replacement and a plug and play replacement microswitch harness. The harness uses a combination of OE Panasonic Switches and Connector/Terminals with a softer more flexible braided wire and silicone insulation.
The parts are available as individual pieces or as part of a complete kit including, upgraded gear, upgraded switches, door panel clips, vapor barrier retainers, and e-clip to secure the gear on the shaft.
Provided you have a Version 2 or 2.5 Handle, We also can rebuild your door handle for you if you feel confident enough to remove it from the car but don't want to take it apart any further.
If the door handle doesn't present then the paddle gear would be what you need to replace.
If the door handle presents but then pops the door open then the microswitches have failed or the grip needs to be adjusted.
You can also watch a good video on how to repair this from The Electrified Garage
Part #'s
1071881-S0-A RF New
1071880-S0-A LF New
1071884-S0-A LR New
1071885-S0-A RR New
