When I just download my monthly data for July from the Tesla Android app v4.23.6 I see positive numbers in the "To Grid" column which is the way that it was originally before it changed to negative at some point. The "From Powerwall' and "Solar Energy" columns swapped positions which was annoying as I had to swap my historical data around so that I can just cut-and-paste new data going forward.Download My Data used to report negative values for kw exported to the grid (consistent with api); now only shows zero. This seems to have occurred with the latest update to gui. Is there a fix for this and/or how can I compute the export value?
Looking at the single day data download, I have Date Time, Home, Powerwall, Solar, Grid and Energy Remaining columns. The Powerwall and Grid data are never negative which is a mistake.Day Download My Data does not show both from and to-grid data. With TOU (net metering) daily total is not useful for estimating daily costs. If Tesla is going to provide data to users, they need to specify when and what changes are made to the data display or interpretation. Not doing so makes using the data presented risky. At present, Download My Data is an unreliable app feature in need of repair.
Energy Use Data -> Green Button -> DownloadI also am PGE. Where/how do you get the data from PG&E?
I've also noticed that the To Grid numbers are way off. It appears they are putting the wrong data in the To Grid column. I even went back a month and the new downloaded data does not match the data I downloaded before. Everything matches except the To Grid Column.Download My Data used to report negative values for kw exported to the grid (consistent with api); now only shows zero. This seems to have occurred with the latest update to gui. Is there a fix for this and/or how can I compute the export value?
If you check out my recent thread on HAN (Zigbee) devices for PG&E:PGE "Energy Use Data -> Green Button -> Download" stopped updating for me on 9/11. Apparently, this is not supported for NEM Paired Storage tariff users and pge has now imposed that restriction! The Tesla data download is still unreliable and rules for the calculation of net grid usage are unknown/specified.
Looking for alternatives for hourly daily net grid usage data capture. Any suggestions?
I can confirm that this has also stopped working for me with no data after 9/11. There is no reason what NEM-PS accounts should be prevented from getting this information as it is just basic readout data from the meter that I believe CPUC mandates providing.PGE "Energy Use Data -> Green Button -> Download" stopped updating for me on 9/11. Apparently, this is not supported for NEM Paired Storage tariff users and pge has now imposed that restriction! The Tesla data download is still unreliable and rules for the calculation of net grid usage are unknown/specified.
Solar Dash for Tesla downloads data (for yesterday) as text in email, not .csv
This should be fixed in the latest version.Solar Dash for Tesla downloads data (for yesterday) as text in email, not .csv
Data has showed up for missing days thru 9/19.PG&E occasionally has data outages / delays, the last one was discussed here:
PGE stopped recording data
I have been tracking my daily PGE use for years and years. I went to check today, and the last recording April 29th, and nothing sense. Has anyone else seen this type of behavior? Weird, since I have changed nothing. Was wanting to see how the EV charging at night nailed the numbers.teslamotorsclub.com
I expect the data to eventually show up.
I'll second a Zigbee solution as backup, I use the Emporia Vue Utility Connect. If you need more data than just grid exports, I developed a mobile app (Solar Dash for Tesla) with improved download functionality over the Tesla app.
I've been waiting for the missing data to backfill into my solar and consumption logging on pvoutput.org, as on 9/9 my SmartMeter was swapped out by PG&E - unfortunately coincident with the Download My Data outage. My Green Button Data as come back, sort of - I can download it, but the typical 15-minute interval data switches to only HOURLY data on 9/9 and continues to the last data points on 9/15. This is within the same CSV data file for the pats month.Data has showed up for missing days thru 9/19.
