Also, on the 163mph limiter limiting 'Ring times - maybe by 5-ish seconds. Even Plaid will not have many places it can touch 163. The 919 didn't crest 300kph (186mph) all that often even with a literal ton of downforce, half as much weight, and cornering at speeds 50kph or more higher than Plaid will be capable of. There are only really three straights where you can deploy a thousand horsepower for more than a few seconds at a time when you also weigh 5000lb. And when you hit the limiter, you're still going 163 mph, which is quite quick, it's not like the car stops...there aren't many cars in the world that will slam into their limiter harder than Plaid, heh. Also, without water cooling or brake fans, I'm not sure how you get Plaid to stop repeatedly from 200mph...you do eventually have to stop to charge the car and when you do you will want the brakes to still be solid. So the 163 mph limiter might only be relevant if you're only doing one lap...these cars are fast enough and heavy enough that they're probably bumping against the limits of materials science in getting a brake to work reliably on a track like the 'Ring. Even carbon ceramics aren't invincible, for that, you need carbon-carbon
