towing_newbie
A web search tells me that trailer has a 2,900 lb dry weight. Add in a few hundred pounds for water and other stuff for a towing weight of around 3,200 lbs. If you have a Tesla 100D it weighs about 5,400 lbs, plus two people and baggage brings it up to around 5,800 lbs. You should use a WD hitch if your trailer weight exceeds 50% of the tow vehicle weight. For more WD hitch info see https://www.etrailer.com/faq-weightdistribution.aspx
My trailer weighs about 2,300 lbs loaded and I tow with the stock Bosal hitch. Have not had any issues. For trailers weighing more than around 2,900 lbs I think that a WD hitch is a very good idea when towing with an X.
I've also been reading that the weight distribution system can damage the Unibody construction. Is there any more information on this? @ohmman any comments on the risks related to using WD system on unibody construction?
